check engine with only TCS codes?
Old Apr 22, 2012 | 06:26 PM
billla's Avatar
billla
St. Jude Donor '14
Default check engine with only TCS codes?
On the way to the airport - do I need to park it and get a cab?
Old Apr 22, 2012 | 06:29 PM
billla's Avatar
billla
St. Jude Donor '14
C1248 is new
Old Apr 22, 2012 | 07:58 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Most common reason for TCS codes is loose or fouled wheel sensor pigtails at each wheel--The TCS uses wheel sensor data to keep the tires from spinning---The ABS usues the sensor data to keep the tires from skidding(on a hard stop)
have you recently driven on a real bumpy road or gone over railroad tracks to fast ? This always sets TCS codes on my car--
To check engine with only TCS codes?
