Front Calipers on Rear
Old Apr 24, 2012 | 11:36 AM
4 KRUSIN's Avatar
4 KRUSIN
Default Front Calipers on Rear
This is probably a stupid question, but here goes:
I have a spare set of powder coated brake calipers for my car. I got thinking - "Wouldn't it look a lot better to have a set of front calipers on the rear as well?"
Is this possible? I am guessing that I may have to change the rear rotors if it is.
PS - I did a search and could not find an answer so pardon me if I'm .
Old Apr 24, 2012 | 05:31 PM
Caesar68's Avatar
Caesar68
This is possible and many have already done it with great success. There is a long thread on this already.
http://forums.corvetteforum.com/c5-t...r-in-rear.html
Old Apr 24, 2012 | 11:24 PM
4 KRUSIN's Avatar
4 KRUSIN
Thanks for the info. It seems it can be done with C6 Z51 rotors in the rear and a couple of minor modifications. It can also be done simply by using C5 front rotors. However, that would mean the loss of the e-brake. Hmmm. I have an extra set of C5 front rotors as well.
Old Apr 25, 2012 | 03:20 AM
RonSSNova's Avatar
RonSSNova
The uprights (spindle mounts) are the same front and rear. So it would make sense that with the front abutments, calipers and rotors it would work.
No E Brake is probably less of an issue on an auto trans car, but still is nice to have.
The question is, what would the bigger brakes do to the proportioning? I would think the rears would want to lock (activate the ABS) much easier?
Ron
Old Apr 25, 2012 | 04:11 AM
C5Natie's Avatar
C5Natie
Ron
Seems that most of the people that have done this mod havent experienced any issues. Almost all have reported better braking power. Im looking at doing this mod myself.
Old Apr 25, 2012 | 11:06 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I have been running this mod for the past month with no issues. Have tried hard braking, and while it activates the ABS on an extreme hard stop no sooner than normally and the rears are not locking up. Performance is at least if not slightly better than stock, but that is a very subjective opinion without before and after actual stopping tests. Just a SOTP judgement. I am looking into an adjustable brake master cylinder to provide some more rear brake to level out the dive on hard stops. I used the C6 Z51 rear rotor in order to keep the E-brake on my 6 speed manual. Also the brackets have to be modified when using the rotor with E-brake.
Old Apr 25, 2012 | 12:47 PM
RonSSNova's Avatar
RonSSNova
Thanks for the info. If nothing else, the bigger brakes will look a lot better......pretty pathetic I know.
What needs to be modded on the brackets? A little machining?
Ron
Old Apr 25, 2012 | 12:57 PM
lionelhutz's Avatar
lionelhutz
Ron
Pictures and a description of what was done are provided...
Old Apr 25, 2012 | 05:10 PM
RonSSNova's Avatar
RonSSNova
Thanks. I hadn't paid attention to all of that until just this week when I disassembled the rear suspension prior to dropping the cradle for trans and diff replacement. I noticed the spindles are the same as the front. Hmmmm.
Ron
To Front Calipers on Rear
