Problem after clutch install
Old Apr 25, 2012 | 02:37 PM
leviathan125's Avatar
leviathan125
Default Problem after clutch install
I installed a clutch in my 02 Z06. Prior to the install, there were no warning lights on. Now, the check engine light is on and the "service traction sys", "service ABS", "service active handling" goes across the display. It is also give a code # C1232 (LF Wheel Speed Circuit Open or Shorted).
This all happened as soon as I started the car for the first time after the clutch install. I don't think I left anything unplugged. The car drives and runs fine, so what could be the problem? Thanks for any help or suggestions.
Old Apr 25, 2012 | 02:49 PM
dougbfresh's Avatar
dougbfresh
Maybe start by checking out the Left Front Wheel pigtail???
Old Apr 25, 2012 | 03:14 PM
leviathan125
I checked that at the wheel and it was plugged in. I don't think the sensor would of went out by just sitting there during the install of the clutch, what would be the chances? Where does the harness go from the wheel? Would it have been something that would of been unplugged underneath for the clutch install?
Old Apr 25, 2012 | 03:18 PM
tommie's Avatar
tommie
did you reinstall the small ground wire on the left rear of the car above the suspension? located in the left rear wheel well and held on by a 10mm nut...
Old Apr 25, 2012 | 03:59 PM
leviathan125
If you are talking about the ground wire on the left side frame rail, just above the muffler, then yes. If not, I'm not sure which one you are talking about then.
Old Apr 25, 2012 | 04:42 PM
tommie's Avatar
tommie
that's what i was talking about... just wanted to make sure you did not forget it.... i know people who have....
Old Apr 25, 2012 | 08:11 PM
Paul 75 L82's Avatar
Paul 75 L82
Clear out the codes and see if they come on again.
Old Apr 26, 2012 | 03:22 PM
leviathan125
I have and the code comes back.
Old Apr 26, 2012 | 04:51 PM
Dope's Avatar
Dope
Resident moron
There's a large wiring harness that runs alongside the torque tube. There's also smaller ones that split out once it reaches the rear axle. Did anyone get pinched or crushed during the install? It's easy to do, I almost made a huge booboo when I did my clutch install. Caught the wiring harness between the bellhousing and the torque tube and started tightening it down...
Dope
To Problem after clutch install
