My oil pump bad?
Old Apr 28, 2012 | 08:28 PM
sfc rick's Avatar
sfc rick
Changed the oil from 5-30 Mobil One to 10-40 Mobil One. The owners manual says that's perfectly acceptable in my area temps. Anyway running cold it was 45psi at idle, and 65psi when running through the gears, and about 50 cruising in 6th at 70mph.
After it got to operating temps of oil being 199-200 degrees, cruising went to 38-40psi 6th gear at 70mph, once stopped it idled at 28-30 psi, but would pump up to 63psi when running through the gears.
Guess there's no problem with the oil pump now, engine has typical sewing machine sound on top end from cam and head work. Nothing screaming out to be worried about.
Here's the Youtube today.
http://youtu.be/Pv9yLS1a898
Old May 3, 2012 | 04:30 PM
mchicia1's Avatar
mchicia1
Sounds normal to me!
Old May 3, 2012 | 04:39 PM
mchicia1's Avatar
mchicia1
Goddd I just saw your 4th video and I am kicking myself for not trying to just retorque my rocker arms before I tore down my car.
I was chasing a ticking noise and I tore down my entire car only to find what appeared to be brand new cam and lifters. Damn!
Old May 3, 2012 | 05:11 PM
chaase's Avatar
chaase
St. Jude Donor '12
On the really, hot days and in stop n go traffic I will see 20psi at idle.
