Looking for clutch master parts
The connection from pipe to end part of the cylinder leaks. The cylinder is fine and fairly new but I'd only need the pipe/hose with the threaded adapter in the cylinder end.
I believe it's RAM master cylinder..?
Leaking part: The steel braided hydraulic hose which turns to steel pipe and is held in cylinder end by a small pin. Leak seems to be somehere around the pin. I know there's seal inside but the quick connector release collar in hydraulic fitting is also in bad shape so I'd like to change the line with end part of the cylinder.
This cylinder is not similar as stock one, you only have 2 parts in stock assembly but I already bought one master cylinder and it came without this part that I need..
If you are wanting a used one, you may want to check with a Corvette used parts vendor.
I suggest trying Mark @ Vettenuts.net
He is out of Tn.
He owns a Vette & is a used Vette parts vendor, here on the forum.
Mark Rose 615 896 6100
http://www.VetteNuts.net
Good luck
