Almost Done...Any Suggestions?
I'm almost done with getting my 98 Vert 6-Spd, 80k miles, sorted. Any suggestions to solve the last few items? I've searched all over the forum, but nothing's helped...No DIC codes at all, cleaned most of the ground connections, especially in the engine compartment.
1. Lumbar short: When I put the lumbar fuse in, there's a "click" on the right side of the console just forward of the e-brake. It creates a battery drain. Already replaced the seat switch. All lumbar functions work fine, but I have keep the fuse pulled.
2. Ignition click: When its cooler outside (< 50 degrees) and the car sits for several days, I often turn the key and get a "click". Rarely is there the "Pull Key 10 Sec" message during my attempts. All electrics work. After 8-12 attempts, it always fires up. Same with my older and newer key, pellets are clean, checked the starter connections below-all good. Battery connections tight.
3. Remote range is very weak. I always have to get close (within a few feet) to the driver side to get it to work. Never works near the passenger side. I've already replaced the battery and cleaned the contacts inside.
Thanks for any advice!
1. In other threads, users have reported the seats being a power drain. Does your lumbar controls actually work properly when you put the fuse in? On both seats? They are supposed to be intermittent when buttons are pressed, so a constant draw is bad. A volt meter/ammeter will help you track it down if you've already replaced the switch. I'll upload the left & right seat electrical diagrams in a minute.
2. If the click is coming from under the hood, I will guess the starter solenoid plunger is having a hard time. Did you confirm the battery is healthy? The next time it happens, you could try throwing on jumper cables to rule out the battery. If it still continues, you can confirm by jacking up the car and use a jumper to short the starter's smaller terminal to the big one. If it just clicks, this is a physical failure in the solenoid. I believe it can be replaced separately, no need to replace the whole starter assembly.
3. The pre-01 RFA is the receiver for both key fobs and TPMS, and has two rabbit ear antennas. It is located behind the passenger seat, tucked up above the rear wheel well. You might check for broken ears or anything obvious. Or if any noise reducing foil-covered insulation was installed up there, it may be blocking the signal. There are many folks who have "upgraded" their older RFAs to 01+, so you should be able to get another one for around $40 in the for-sale section. I happen to have one if you're interested.
If you figured out #1 after a couple of dead-battery discoveries, you may have injured the battery enough causing #2. There are 3 relays on each lumbar control board, and is almost certainly the click you're hearing. Did you replace the driver's seat switch, or passenger's?
Low voltage may also cause the RFA range to diminish. Do you have 2 fobs to test with?
Hope this helps!
Todd
Now, regarding the RFA module, I found it on the driver's side. No apparent problems with it or the antennae. I checked the connector and didn't see any issues, so maybe I'll consider replacing it. I only have one fob to test it. I should note that my wheels don't have sensors, put I doubt that would negatively impact the fob functions...
On the key fob range issue, it takes 2 pieces to successfully communicate - the transmitter and the receiver. If you had 2 fobs and they both behaved the same, the RFA is 100% the issue. The TPMS are also transmitters, so if they were also intermittent it may indicate the RFA. With just one key fob it's not as certain.
If you have any buddies with a pre-01 C5, you can train up one of their fobs with your car to see how it's range is.
Todd
