Clutch grind in 1st
Old Apr 29, 2012 | 06:25 PM
rttmike's Avatar
rttmike
Default Clutch grind in 1st
I did a search and after page 8 I could not find what I was looking for.
This happened to me twice today in 2 different parking lots. I was in first gear letting the clutch out and I got a quick grind. It stopped when the clutch pedal was completeely out. It was not like a gear grind either. It sounded like the clutch grinding as it engaged. The clutch has about 17k miles on it.
Any ideas?
Old Apr 30, 2012 | 08:21 AM
johnson-rod's Avatar
johnson-rod
I wouldn't say it's a grind but there is a funny little rattling sound when you let the clutch out. It's normal.
If it's a real grind then you have other problems.
Old Apr 30, 2012 | 12:33 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Try bleeding the cluch fluid
Old Apr 30, 2012 | 02:20 PM
waddisme's Avatar
waddisme
If it is grinding just starting in first or reverse, it is probably pilot bearing. Only a $8 part, but a lot of labor to get to it. I hope it is something else, but sounds like pilot bearing to me. Good luck with it.
Old May 13, 2012 | 06:15 PM
rttmike's Avatar
rttmike
I am hoping this is not a pilot bearing.
Today the noise came back. It did it at every light. But now it's gone again. This whole thing is strange. It comes and goes.
Old Jun 15, 2012 | 12:05 AM
joopblog's Avatar
joopblog
Default Grinding sound in first
I was at Laguna Seca a couple weeks back, during one of the sessions, I was getting a vibration on left turns, then I started hearing a grinding sound only when starting out in first, with no sound with the clutch pedal pushed in. A couple other corvette experts listened and thought it sounded like the throwout bearing, but after I spent 6 hours disassembling, I discovered the pilot bearing was dust (literally) and the input shaft of the torque tube was scored. Wow, it happened very fast, never heard it before that day. I road race one day a month, for about the last 5 or 6 years. What a huge project! I had to use a modified harbor freight pilot bearing puller to get mine out, since there was only the outer race of the bearing remaining. It's forcing me to do some preventative maintanence and I'm also replacing the rubber couplings, since I have to assume those were shot, causing the torque tube to wobble. Or, the other possible cause was the pilot bearing was put in backwards or somehow there was no grease in the pilot bearing.
Old Jun 15, 2012 | 09:22 AM
rttmike's Avatar
rttmike
Did yours always do it? Or just randomly? I have noticed that mine will only do it sometimes and only when the clutch is warm. It never does it after the car has been parked.
Did yours sound like this? I made a short video.
http://www.youtube.com/watch?v=8XRqe...ature=youtu.be
Old Jun 16, 2012 | 05:56 PM
sccs's Avatar
sccs
your video does not work
Old Jun 17, 2012 | 09:31 AM
rttmike's Avatar
rttmike
This video should work.
Old Jul 27, 2012 | 12:28 PM
alabaster z's Avatar
alabaster z
Default That's it exactly!
My 2002 Z does the same thing, first and reverse...pilot bearing could be it. Might as well go with the new clutch(LS7).
Old Jul 27, 2012 | 12:54 PM
alabaster z
...The Textralia clutch I have is a pita to drive, give me the LS7 clutch w/ pilot bearing while they're at it.
Old Feb 14, 2013 | 06:15 PM
YellowSpade's Avatar
YellowSpade
Cruising
This is happening to my c6 OEM clutch and is slowly lasting longer through the pedal... fades to nothing when warm or fully engaged.
Old Feb 14, 2013 | 08:39 PM
alabaster z
Default Still Going
I was concerned about this for a while, but the Textralia clutch could be the issue(6-puck), the car runs fine, except for the ocassional noise on slow engagement. When I take off quickly under strong acceleration the clutch doesn't sound off at all...could be some glazing, but I am not sure, I'll just keep driving. I have a remote bleeder, and changing out the fluid made no difference in the sound.
Old Mar 24, 2015 | 02:11 AM
mike9812121298's Avatar
mike9812121298
mine seems to be doing the same thing. almost like a grinding noise coming from the front of the car when in 1st and reverse. it just started this last weekend but the car was sitting for the last 5 years before that
Old Mar 24, 2015 | 09:12 AM
Uhhtaken's Avatar
Uhhtaken
From: Jacksonville,nc and Williamsburg,va North Carolina and virginia
Mine had been doing this for a few months but I figured out if you are easy on getting the car moving (under 1k rpm) mine wouldn't make the noise, but this past weekend I replaced the slave and pilot bearing now I have no noise what so ever. By the way the pilot bearing was completely trashed.
Old Mar 24, 2015 | 02:00 PM
Trios's Avatar
Trios
I fourth (fifth? sixth?) the motion of the pilot bearing being at fault. Sounds exactly like what mine was doing, shop pulled the driveline and found a trashed pilot bearing and scored torque tube input shaft.
Old Mar 24, 2015 | 04:32 PM
mike9812121298
Did your cars sound like this?
http://www.youtube.com/watch?v=1Rmw0c0MzGg
http://www.youtube.com/watch?v=AEiqgg9oyMU
http://www.youtube.com/watch?v=4bGKwfqHxN4
To Clutch grind in 1st
Old Mar 25, 2015 | 12:34 AM
c5z06.O's Avatar
c5z06.O
Default What will you replace
If it's the bearing. Are you going to replace the clutch? Which one? The slave? Stock or aftermarket? Might as well change everything. Labor cost sucks. Im going through the same motion. Just waiting to see what parts I should upgrade to. Its going to cost. But hopefully last more than the previous installment. By the way. I have the ls7 clutch. But I think my problems lay with the slave or the bearing. Who knows.
Old Mar 25, 2015 | 01:27 AM
mike9812121298
I was looking at doing it myself. I found a pretty good write up on it.
http://www.smokinvette.com/corvette/...a-c5-corvette/
IM guessing your going to be 2.5k+ for a shop to do it for you. If you did it your self 500-900 depending if you go stock or aftermarket
http://monsterclutches.com/c5-corvet...12-inch-clutch
Old Mar 25, 2015 | 07:16 AM
Uhhtaken's Avatar
Uhhtaken
I did mine myself and it wasn't too hard, first time was on a lift which made it a breeze and the second was on jack stand which since I already had been in there once I knew what all had to be done, but while I was in there I went ahead and replaced everything for good measure and not wanting to do it all over again. Hope that helps.
