FOB issues
Old Apr 30, 2012 | 06:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default FOB issues
replaced the battery in my #1 FOB and reprogrammed it...now when I hit Lock or Unlock the lock mechanism double functions meaning it sounds like I double press the button....#2 FOB works fine.
Any thoughts??
Old Apr 30, 2012 | 07:55 PM
65GGvert's Avatar
65GGvert
Sounds like you may have a broken solder connection on the board, causing a quick connect, disconnect, then reconnect. If it was just one button, it could be dust or corrosion in the button, but if both lock and unlock do it, it really sounds more like a printed circuit strip cracked or solder connection loose.
