Help needed with 3rd brakelight problem on 90 vert.
Old May 21, 2002 | 01:15 AM
Charcoal Grey 90's Avatar
Charcoal Grey 90
Default Help needed with 3rd brakelight problem on 90 vert.
Failed NJ inspection last week due to the third brakelight being out. I remember reading something on this topic months ago, so I hope someone can help me out. The bulb and socket are OK. I'm getting 12 volts to the base of the bulb & the socket has a good ground. I verifed this by removing the socket assembly and tested with a battery. The problem seems to be current related. Any advise regarding this issue is most appreciated.
Regards,
Old May 21, 2002 | 06:54 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: Help needed with 3rd brakelight problem on 90 vert. (Charcoal Grey 90)
Hi there,
I would check to see if there is not high resisitance somewhere in the grounding circuit.
You should only have 12 volts when you depress the pedal.
I would go here first.
Besttoyou, c4c5 :crazy:
