TT Bushing
Old May 3, 2012 | 05:50 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default TT Bushing
I have a worry that my TT bushing is on its way out. I wanted to know how I can tell if this is an alignment issue, some other mystery, or truly the TT bushing? I have heavy vibration on acceleration more vibration with heavier throttle. I read in a different thread that sometimes rear cradle alignment can cause problems and also the TT alignment can cause vibration.
History: 6 months ago replaced slave cyl. and had TT back removed. 5 months ago new tires and lowered stock bolts.
I may have had this vibration for a wile but never noticed it because my exhaust and stereo cause some pretty violent tremors but now I know its bad because I see my rear view shaking pretty badly.
Is there some testing that I can do to narrow it down? If not I am going to try and get on a alignment rack tomorrow (if the car is not too low) and I have bushings ordered and here in 3 days so I am bound to figure it out just seeing if anyone can help ease my mind or save some time and money.
Old May 3, 2012 | 09:26 PM
bumble-z's Avatar
bumble-z
Can you feel the vibration coming up through the shifter handle?
Old May 3, 2012 | 09:35 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Yes and in the floor/ petals.
Old May 3, 2012 | 09:48 PM
bumble-z's Avatar
bumble-z
So according to your profile, your pretty much at stock HP level?
How many miles on car?
Did you buy new?
Do you drive the car hard through the gears, as in high rpm power
shifting?
Can't understand why the bushings were not inspected when the tube was out for the slave replacement.
Did you do the work or hire it out?
Old May 3, 2012 | 10:14 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I do not drive it like I stole it everywhere but don't baby it either usually shift 3-4k rpm. It is an 04 with 70k I bought it last year with 63k. I changed the slave but did not think to check the bushings.
Old May 3, 2012 | 10:15 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Hp still under 400
Old May 4, 2012 | 06:46 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
If it is a bad bushing, what kind of damage can occur?
Old May 4, 2012 | 07:48 AM
bumble-z's Avatar
bumble-z
Once the rubber couplers have become worn, desinegrated & out of round it could cause the the wear of the inside to outside of the t/tube.
Old May 4, 2012 | 08:38 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
is there any concern with this wear that can be caused? Also is damage to the flywheel a concern?
Old May 4, 2012 | 09:19 AM
bumble-z's Avatar
bumble-z
As mentioned, if it is indeed a bad coupler, vibrating inside the t/tube....
If left unfixed & continued under those conditions, could cause wear to the inside of the tube.
Read these posts below
http://forums.corvetteforum.com/c5-t...with-pics.html
Old May 4, 2012 | 09:44 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Sorry I meant if the bushing is shot and there is damage to the tt what could I look for once I have taken things apart
Old May 4, 2012 | 12:42 PM
lionelhutz's Avatar
lionelhutz
It will be obvious once you take it apart. The bushings will be all cracked and falling apart. Look for wear on the inside the tube if you find them coming apart.
There is a hard round insert for each bolt in the coupler. What can happen as the rubber fails is that these inserts come together and ride over each other, bending and/or breaking the bolts. Then, the bend pieces or loose parts can catch between the drive flanges and the tube and they get driven through the tube destroying it.
Old May 4, 2012 | 01:29 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I found a good visual I will take some pics and keep you posted.
Old May 7, 2012 | 06:16 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I got off cheap!! Turned out to be a bent rim. so I will hang on to those bushings I ordered for the next time I have the rear end off. Thanks for the help!
To TT Bushing
