lower plastic part on driver's seat...
Old May 5, 2012 | 01:04 AM
claytoncramer's Avatar
claytoncramer
Default lower plastic part on driver's seat...
There's a plastic part that goes from the recliner lever around to the lower front of the driver's seat that provides significant structural support for the left bottom bolsters. (It's like the buttress that holds up the walls on a medieval cathedral, but less artistic.) This part has failed before, and it has failed again, causing the driver's seat to sag to the left. (Yes, I have already done the foam insertion to solve the cut bolsters.) What is the name of this part, so that I can search for it? Has anyone thought of replacing this with something a bit more durable, perhaps made of aluminum or steel?
Old May 5, 2012 | 11:32 PM
Dixiecrat's Avatar
Dixiecrat
I have the same problem, Ill be watching this post ! Bought my 03 from a Fat Doctor with 8700 miles on it and he already broke it,lol.
Old May 5, 2012 | 11:49 PM
LoneStarFRC's Avatar
LoneStarFRC
Are you speaking about item #7? If so, this is NOT a structural support piece. It is a trim (or "garnish") piece only.
If you have replaced seat foam in the past, did you install some extra padding over the "trapeze" to help prevent the wires on the trapeze from cutting into the foam in the future? Also, one other thing to look at is item #39 in the illustration, that is the "trapeze"; otherwise known by GM as "Front Seat Cushion Wire". It may have one or more wires broken and this causes sagging where the broken wires are. If any of the broken wires are towards the left side, this could very well be the reason your seat "leans". The trapeze is not terribly difficult to replace, but the seat definitely has to come out and the seat foam removed to access it.
http://parts.nalleygmc.com/showAssem...&searchString=
Old May 6, 2012 | 07:26 AM
Cybermind's Avatar
Cybermind
Agree! Having just changed my seat covers, I can confirm that the piece you are referring to is not structural. Either your seat foam has broken down in that area or the bottom wires have cut through it. I added a thick synthetic "shammy" over the wires before re-installing my seat foam. I used hog rings to pull it tight over the wires.
Old May 7, 2012 | 12:30 AM
claytoncramer
Default seat surgery
Sure enough, it is NOT structural. I replaced it, but I also went in and did a bit more reinforcing with foam. The core problem here is that the seat frame has sliced into the bolster foam on the left side of the seat, probably because when I am exiting the car with the top on, I tend to press on it.
When I went in yesterday afternoon to take another look, I did a more complete job of reglueing the split bolster foam, but there still isn't enough pushing up to even out the left and right bottom seat bolsters. My next step:
1. Put in another inch or so of foam under the left bolster.
2. To prevent the sharp edge of the seat frame from doing any more damage to the foam, take a thin sheet of aluminum and bend it over the seat frame on both sides. This will mean that I will not have a sharp edge to cut the bolster foam, and it will provide a bit more support.
Many years ago, a couple of friends bought the 9C1 police car package option on a Chevy Impala and a Chevy Malibu. Along with durability and performance improvements, an unexpected part of the package was the "heavy duty front seat." I discovered that this was a vastly more comfortable seat than the standard sedan. It was much firmer--almost like a Mercedes-Benz seat of that era. It wasn't because the foam was firmer, but because the underside of the seat frame was a solid sheet of metal, where the standard sedan seat had a cutout under the buttocks.
As near as I can tell, the standard seat had the cutout so that when you did a test drive, you would sink into the seat, and for the few minutes of a test drive, it would be oh so soft! But in practice, after 30 minutes driving on an unsupportive seat, you begin to appreciate the extra firmness. Think of sleeping on a soft mattress, versus a firm one.
Old May 7, 2012 | 01:09 AM
LoneStarFRC
Were you able to checkout the seat wires (trapeze) as well? Was it OK?
Old May 7, 2012 | 08:50 AM
claytoncramer
Default wires
Yes. The only problem is that the left seat bolster was split and reduced in height because of it.
Old May 7, 2012 | 03:49 PM
Dixiecrat's Avatar
Dixiecrat
Looks like mine is #7
Old May 9, 2012 | 03:35 AM
Dixiecrat's Avatar
Dixiecrat
Went to the dealership today and ordered #7, $23
Old Oct 19, 2015 | 10:55 AM
huesmann's Avatar
huesmann
Arise, o necrothread!
How do you remove the handle on the outside of the panel in order to replace the panel?
Old Oct 19, 2015 | 07:04 PM
Vanover's Avatar
Vanover
Watching
Old Oct 19, 2015 | 07:35 PM
73Corvette's Avatar
73Corvette
Clip part #10 just like the old clips holding the crank on GM windows...
I modified a paint can opener from lowe's to pull these retainers...
http://www.wholesalegmpartsonline.co...&searchString=
Old Oct 19, 2015 | 09:20 PM
huesmann's Avatar
huesmann
If you still have it, can you please post a pic of how you modded it?
To lower plastic part on driver's seat...
