I was looking into a cam setup for my 2003 C5, which has 115,000k on it. I was looking at Comp Cam's xr259hr and xr265hr's. The car's s a daily driver for me and I was concerned about the mileage. Someone suggested looking into Comp's xr273hr, but Idk if that cam would be too big, plus I believe it requires a computer modification. Besides a cold intake, she's completely stock. Any suggestions would be a great help!
I've had the vette for a while now, and with a new daily drivier I decided more power at the low end would be something different/fun.. so that's why I was looking into cams.
I really just want some power above stock, without breaking bank. This car was my daily driver for a while, and now I don't drive it as often, but when I do, I'm looking at around 45-60 mile trips at one time. Ideally, I want reasonable drivability (I understand it wont be as reliable as stock), but a bit more torque of the line. One of my buddies swapped comps 259hr cam, in place of stock, but like you said, he was looking at the 1000$$ range, and that was a weekend car. It idled great though, and had noticeable pick up (at least to me). Given all this, is cam swap worth it, or should I just stick to stock?
some of the smaller cams from vendors like TSP, thunder racing, or EPS offer smaller cams that will give you a nice increase in power and if installed correctly will still be a daily driver, easy going, with a minimal decrease i n mileage (gotta pay a price for the more power somewhere) the issue though is the money. cam kits are going to run around 1K for everything you need, (cam, gaskets, springs, pushrods, etc) plus another 4-500 for a tune. If you want a nice bump in power without having to go into the engine look at long tubes and a mail in tune.
Only you can decide what worth it to you. As saying goes, "Speed costs money, how fast do you want to go?"
With 115,000 miles on the engine you are talking about close to $2000 or so to make it as reliable as stock. The valve train would need to be updated and it will need a tune.
You may / should need to replace:
Cam
lifters / trays
Springs / retainers
Seals
Timing chain
Oil pump
Gaskets / bolts
Push rods
Trunion upgrade
Tune
Cam
lifters / trays
Springs / retainers
Seals
Timing chain
Oil pump
Gaskets / bolts
Push rods
Trunion upgrade
Tune
And thats assuming you can do the work yourself.
some people think that a cam upgrade is just the cam, but there are so many other things that need to be done to make sure your car runs reliably its not funny.
to the OP think of how long you are going to keep this car. think of what your future plans are and think of how much money your going to invest in it. with a 115K miles I would keep it stock and drive it for another 100K miles and then get a C6 with a lot lower miles and do your upgrades, or get a new short block or refurbished one and do your upgrades. Your window for upgrades really past at around 80K miles.
Thanks for all the input. After considering what you all said, and considering expenses and maintenance, I think I'm gna keep it stock. I enjoy driving it frequently without the headaches. A cam, with lifters, rods, and retainers alone is looking close to 1000$ and that's without the tune, or timing chain etc...so I'm thinking it ain't worth it considering the 115,000 miles. Prob put that money into making it run for another 115,000 miles strong.
Change the rear end ratio if you want an increase in the seat of the pant's feeling. Go to a 3:42 if you have an a4 or 3:90s-4:10s if you have a 6 speed. Mileage will not be a lot different and you will gain good acceleration.
