C5 electronic messages/gauges
Old May 21, 2002 | 06:17 PM
johnsct's Avatar
johnsct
Cruising
Default C5 electronic messages/gauges
2001 coupe, 7k miles - developed a problem where the fuel gauge suddenly goes to empty from just under half-full, and I get a message to check the gauges and a message for low fuel. Anyone has seen this? Any easy remedies or do I have to face the dealer service... which in my area (San Jose, CA) is a daunting prospect.
Old May 21, 2002 | 07:38 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: C5 electronic messages/gauges (johnsct)
There is an easy remedy,but it will require a trip to the dealer...There is an updated PCM calibration to correct :yesnod: for 2001-02...
Old May 21, 2002 | 10:53 PM
Hex29A's Avatar
Hex29A
johnsct
Run a search for fuel gauge. You'll find a lot of information.
Old May 22, 2002 | 02:10 PM
EHS's Avatar
EHS
Default Re: C5 electronic messages/gauges (C-5 TECH)
C-5 Tech:
Is this new? I thought there was a TSB for the P1431 code, and you had to replace the fuel sensors? I remember you posted the original text for it.
:confused: :confused:
Old May 22, 2002 | 08:32 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: C5 electronic messages/gauges (EHS)
The TSB for the fuel senders addresses the 97-2000...Within the last month or so,a TSB was released for a PCM program update to address the 2002 gauge...Within the last 2 weeks,a PCM program update was released to address the gauge problem on the 2001,yet no info or TSB was released (I stumbled upon it when performing a PCM update on a 2001 for another concern ;) )
So if you read between the lines here,considering that the 2001-02 are still having a problem when they allready have the updated fuel senders that are being installed in the 97-2000 per the TSB...well you get the point ;)
Old May 22, 2002 | 08:35 PM
EHS's Avatar
EHS
Does that mean a PCM flash for my 2000 C5 convertible, which has now had three sets of sensors in the last +/- year is on the way? :confused:
Old May 22, 2002 | 08:49 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
EHS,e-mail me...
Old May 22, 2002 | 11:14 PM
EHS's Avatar
EHS
You have mail.
To C5 electronic messages/gauges
