Active Handling after ABS Fixer
Old May 9, 2012 | 05:27 PM
RutRoe's Avatar
RutRoe
Default Active Handling after ABS Fixer
I have had the EBCM Module repaired by ABS Fixer and I am not concerned about the repair. They always get it right. The 1214 code has gone, but I am still getting Active Handling on the DIC and the brake applies. I'm puzzled. Any help out there?
Old May 9, 2012 | 05:32 PM
dougbfresh's Avatar
dougbfresh
Did you clear the codes after you installed the repaired module?
Old May 9, 2012 | 05:46 PM
RutRoe's Avatar
RutRoe
Cleared codes, not throwing codes now, new stock size tires, ABS Fixer repair.
Old May 12, 2012 | 01:25 AM
RutRoe's Avatar
RutRoe
Originally Posted by 8VETTE7
Pull the codes and post them. If there are no codes for TCS then pull them again with the engine running.
http://www.c5forum.com/ayc/dtcdic.php
I konw how to get the codes with the engine off. But how do I get them with it running?
Old May 12, 2012 | 01:29 AM
whitehooptie's Avatar
whitehooptie
The same way....
To Active Handling after ABS Fixer
