Lighter/accessory outlet
Yesterday both my dash and glove box accessory outlets went out dead wihich I'm sure means a fuse blew. Does anyone know which fuse it is ("03" C5 - LS). The fuse box does not have it identified and I don't want to pull every fuse to find out. Thanks for the help.
Bob
Bob
Fuse/Circuit Breaker/Relay
Rating
Description
1
CNSL CIG Fuse
20A
Auxiliary Power Outlet
2
MONITORED LD Fuse
10A
Underhood Lamp, Body Control Module (BCM), I/P Compartment Lamp, Vanity Mirror Lamp - Left, Inside Rearview Mirror, Vanity Mirror Lamp - Right
3
LUMBAR Fuse
15A
Seat Pump - Passenger, Seat Adjuster Switch - Passenger, Seat Relay Center - Passenger
4
SCM-L Fuse
10A
Seat Adjuster Switch - Driver, Seat Control Module (SCM) - Driver (w/AQ9), Seat Relay Center-Driver (w/AR9)
5
RDO/CD Fuse
15A
Radio, Remote Playback Device - CD Changer
6
PK T/LP Fuse
10A
ALC PRK LP Relay, A/T Shift Lock Control Solenoid, Multifunction Turn Signal Lever
7
C/LTR Fuse
20A
Cigar Lighter
8
STP HZD Fuse
20A
Stop Lamp Switch, Hazard Switch
9
BCM A Fuse
10A
10
WSW Fuse
25A
Windshield Wiper/Washer Switch, Windshield Wiper Motor
11
ASRYOFF Fuse
20A
Accessory Power (Blunt Cut)
12
Not Used
13
BCM I1 Fuse
10A
14
CRK Fuse
10A
Clutch Pedal Start Switch, Park/Neutral Position (PNP) Switch
15
HZDT/SG Fuse
20A
Hazard Switch
16
SDM Fuse
15A
Inflatable Restraint Sensing and Diagnostic Module (SDM)
17
TONN REL Fuse
10A
TONN REL Relay
18
HVAC Fuse
10A
HVAC Control Module, Air Temperature Actuator - Right, Vacuum Control Assembly, RR DEFOG Relay, Air Temperature Actuator - Left (C60), Blower Motor Relay
19
IPC Fuse
10A
Instrument Panel Cluster (IPC)
20
CR CONT Fuse
10A
21
BTSI BU Fuse
10A
Park/Neutral Position (PNP) Switch, Backup Lamp Switch, Inside Rearview Mirror
22
Not Used
23
BCM 2 Fuse
10A
Body Control Module (BCM), Steering Column Lock Relay
24
RDO/ANT Fuse
20A
Bose Signal Processor, Radio Power Antenna
25
BCM and IPC Fuse
10A
Body Control Module (BCM), Instrument Panel Cluster (IPC)
26
HTCHTRK Fuse
10A
Rear Compartment Lid Latch/Latches
27
HVACCON Fuse
10A
HVAC Control Module, Remote Control Door Lock Receiver (RCDLR)
28
BOSE Fuse
20A
BOSE Relay
29
C/LADL Fuse
10A
Data Link Connector (DLC), CTSY LP Relay
30
DCM-R Fuse
10A
Passenger Door Module (PDM)
31
PWRFDR Fuse
25A
32
F/TNKDR Fuse
15A
Rear Compartment Lid/Fuel Door Lock Release Switch (Export), Fuel Door Lock Release Switch (Domestic), Traction/Suspension Control Switch, Fog Lamp/Rear Compartment Lid Release Switch (Domestic) Fog Lamp Switch (Export)
33
DCM-L Fuse
10A
Driver Door Module (DDM)
34
PWRFDL Fuse
25A
35
PWR ST/DRV Circuit Breaker
20A
Seat Control Module (SCM) - Driver (w/AQ9), Seat Relay Center - Driver (w/AR9)
36
PWR ST/PAS Circuit Breaker
20A
37
MONITORED LD Relay
38
DRL R Relay
Park/Turn Signal Lamp - RF, Turn Signal Lamp - RF, Repeater Lamp - Right
39
HTCHTRK REL Relay
40
DRL L Relay
Park/Turn Signal Lamp - LF, Turn Signal Lamp - LF, Repeater Lamp - Left Park/Turn Signal Lamp - RF, Turn Signal Lamp - RF, Repeater Lamp - Right
41
TONN REL Relay
Folding Top Lid Latch, Folding Top Release Switch, Body Control Module (BCM)
42
CTSY LP Relay
Courtesy Lamps
43
ALC PRK LP Relay
44
ALC HDLP Relay
45
BOSE Relay
Speaker - LF Door, Speaker - RF Door
46
RRDEFOG Relay
Rear Defogger
47
IGN 1 Fuse
60A
Ignition Switch
48
RRDEFOG Fuse
40A
RR DEFOG Relay
49
Not Used
50
IGN 2 Fuse
60A
Ignition Switch
51
BLO MOT Fuse
30A
Blower Motor Relay, Blower Motor Control Processor
52
STARTER Fuse
60A
Theft Deterrent Relay
53
Not Used
54
HDLP Circuit Breaker
20A
Multifunction Turn Signal Lever, ALC HDLP Relay
