Im looking into torque wrenches since Im going to be upgrading my heads in the next week or so, any recommendations? Im not looking for anything super fancy but I did see that Jegs sells a digital wrench that measures both in-lbs and ft-lbs. The other one I was looking at was Eastwoods digital but Im open to any and all ideas.
I was about ready to respond, and then I thought .....WAIT...there is a search function! I bet someone has asked this very same question before!
Made in China and critical torque readings don't really jive.............Yes, I just torqued down my $250 ARP head studs with a $20 harbor freight tool........??......doesn't add up.
I ended up going with the Eastwood Tools torque wrench that also does degrees since thats what is required for the head bolts. It had really good reviews on the web site, we'll see how it works out
I use a Craftsman ft lbs wrench and I got an in lbs wrench at Autozone... only used the little one to torque down the rocker arms.
little one? as in inch lbs? 264inch/lbs without looking at the TQ spec in the book(22ft/lbs), I'm sure you realize the difference in inch/ft/lb torque, but wanted to be clear for anyone else reading
Yeah, I have two separate torque wrenches. The big one measures in ft lbs and I'm sure most of you would recognize it right away. My smaller one (about 1/3 length of the Craftsman) is calibrated with in lbs measurements.
