little smoke at idle
Old May 10, 2012 | 10:53 PM
leo97's Avatar
leo97
Default little smoke at idle
Im getting a little smoke at idle. I took the oil cap off and didnt see any smoke. I replaced the pcv valve and installed a catch can but still get a little smoke. If i rev to about 3000rpm i get alot more smoke. How can i tell if its the valve seals or the rings?
Old May 11, 2012 | 12:44 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
What color is the smoke ?
Does it smell ?
When you put your hand over the exhaust pipe--does it get moist ?
Is the Eng using any oil ?
Old May 11, 2012 | 01:01 PM
dougbfresh's Avatar
dougbfresh
Compression test is your first test.
Old May 11, 2012 | 02:56 PM
Kmcoldcars's Avatar
Kmcoldcars
Valve seals generally make the car smoke when it is first started. Rings would cause smoke while running. First do a compression test. All readings should be within a few pounds of each other. If one or more cylinders is low you have a problem. You can squirt some oil into a cylinder that shows low compression and then recheck its compression. If it comes up then you have bad rings. If it stays low then it is valves.
Old May 11, 2012 | 03:19 PM
lucky131969's Avatar
lucky131969
....provided he is burning oil, and not coolant. Rings are not the only thing that will cause oil burning while running.....i.e. an overserviced crankcase.
To little smoke at idle
