Front end rattle
Old May 13, 2012 | 03:43 PM
dtcswaw's Avatar
dtcswaw
3rd Gear
Default Front end rattle
Recently swapped out in Tremec tranny in my 98 C5. Replaced slave cylinder, pilot bearing, flywheel, etc. Also went with Centerforce dual friction clutch.
Since I had this work done, there is a loud rattle in the front end. Thought it might be a bad clutch. Took it to another mechanic with corvette background for test drive. He doesn't think it's a clutch issue at all. He checked the motor mounts, suspension, etc. Didn't have a lift available to dig any deeper at the time.
The noise gets louder as I steer left to right (at any speed).
Just wondering if anyone out there has experienced similar problem.
Thanks!
