Anyone else lost a rocker arm?
Old May 22, 2002 | 09:59 AM
jefffxdwg's Avatar
jefffxdwg
Default Anyone else lost a rocker arm?
The rocker arm it self looked okay but the bearings came apart. The needle bearings were all over, had to pull the pan to remove them all. Is this a common failure?
[Modified by jefffxdwg, 7:59 AM 5/22/2002]
Old May 22, 2002 | 10:08 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Anyone else lost a rocker arm? (jefffxdwg)
Sheesh... I hope not! Let us know how it turns out...
Old May 23, 2002 | 11:49 AM
jefffxdwg's Avatar
jefffxdwg
Default Re: Anyone else lost a rocker arm? (Umrswimr)
No one else has seen this?...........Good
Old May 23, 2002 | 11:57 AM
Av8ter's Avatar
Av8ter
I believe FCalmes on the Z06 vette website did,,,,,,,,i cant believe this website wont allow you to post other websites without changing the name back to corvetteforum
[Modified by Av8ter, 10:00 AM 5/23/2002]
Old May 23, 2002 | 11:59 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
guys with mods to the valve train over on the F body sites see this problem. :chevy
Old May 23, 2002 | 12:58 PM
Miles in Michigan's Avatar
Miles in Michigan
Default Re: Anyone else lost a rocker arm? (clem zahrobsky)
will it let us post links?
Here goes... http://www.ls1tech.com http://www.ls1.com
Old May 24, 2002 | 02:40 AM
bparker's Avatar
bparker
I have broken two on my previous 99 A4 and when I spoke to the dealership here about it - they told me that (unfortunately) this is a very common issue. Although, mostly accompanied with F-Bodies, it happens to the C5s as well.. I personally know of 4 people (including you) that have had to have one or more replaced..
Best Regards,
Old May 24, 2002 | 07:52 PM
gpflepsen's Avatar
gpflepsen
Default Re: Anyone else lost a rocker arm? (bparker)
Haven't had a bearing failure, but I had a rocker arm mounting bolt back out so the rocker fell off it's seat. No damage, but is sounded bad.
To Anyone else lost a rocker arm?
