Tested my A-A Frame Savers yesterday...
Old May 22, 2002 | 11:11 AM
Cybercowboy's Avatar
Cybercowboy
From: Blacker than the blackest black, times infinity.
Stealthy Puma Member
Cruise-In IV Veteran
Default Tested my A-A Frame Savers yesterday...
I bolted them on the front frame a few months back and they had never touched anything - until yesterday. They are just bolted on through the holes I drilled, and not welded.
I was driving in a residential neighborhood behind another car when, at the last second, I see the car in front swerve. I thought a dog or something was in the street and only too late did I realize that he was avoiding a crater-sized pothole. :eek: :eek:
I nailed it at about 25 MPH and bounced the frame on the drivers side pretty hard it seemed. I drove it home and looked under the car. A little scuff on the frame just behind the frame saver "skateboard wheel" and the wheel itself was a little scuffed. I think it saved my air dam from getting nailed. Anyway, it seemed to take the abuse just fine. Just thought somebody out there would be interested. :)
Old May 22, 2002 | 12:09 PM
jefffxdwg's Avatar
jefffxdwg
Default Re: Tested my A-A Frame Savers yesterday... (Cybercowboy)
My A-A rocker rail protectors save my azz all the time. :cheers:
Old May 22, 2002 | 03:35 PM
ddawson's Avatar
ddawson
I waited to long because my driveway does this :eek:
Old May 22, 2002 | 03:45 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: Tested my A-A Frame Savers yesterday... (ddawson)
DDawson,
Is that frame a whole solid piece??? Just worry about drilling it
That is neat ... gotta do it some day :cool:
Old May 22, 2002 | 04:00 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: Tested my A-A Frame Savers yesterday... (mike76002)
I also like my frame savers! :D :cheers:
Old May 22, 2002 | 04:54 PM
ddawson's Avatar
ddawson
No its hollow. Very easy to drill.
Old May 22, 2002 | 09:19 PM
Quicksilver01's Avatar
Quicksilver01
What a great idea. Where did you get the A-A Frame Savers?
Quicksilver
Old May 22, 2002 | 09:39 PM
aces's Avatar
aces
Did you weld them also? I did. :cheers:
Old May 22, 2002 | 10:38 PM
ddawson's Avatar
ddawson
Default Re: Tested my A-A Frame Savers yesterday... (aces)
Not welded yet Aces. I have to make time to see a friend with a welder.
You can get these from Andy at http://www.aandacorvette.com. Andy is a Forum Sponsor as well.
Old May 22, 2002 | 11:47 PM
MelloYellow's Avatar
MelloYellow
My rubber wheels get a lot of use and look kinda chewed up after less than 4 months use!! They definitely help.
Old May 23, 2002 | 12:34 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Boy, that would make all the towing and flat-bedding that happens to my car go a LOT smoother and quicker if I didn't have to worry about the nose, air dam, and frames. :D
Old May 23, 2002 | 11:28 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Tested my A-A Frame Savers yesterday... (Brett C5 SCCA)
Brett I was thinking of making some sort of a tow hook that mounts behind the front license plate. Maybe some of you racer guys would be interested in that?
To Tested my A-A Frame Savers yesterday...
