Leaky Rear axle
Old May 15, 2012 | 12:18 PM
Harrys Kid's Avatar
Harrys Kid
5th Gear
Default Leaky Rear axle
Found some clear oil on the gagage floor under the rear axle with a strange smell coming from the area. Is this seals on my 99 with 11,000 miles.
Old May 15, 2012 | 12:22 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
probably one of the side seals....replace both they are cheap...repair with a competent shop not jerking you around should be under 2 hours
Old May 15, 2012 | 12:34 PM
bumble-z's Avatar
bumble-z
Look at this area, where the half shafts come out of the differential.
( seal is the the round center section that has the orange paint marking.)
There are one on each side of the differential.
The driver's side is more common to leak.
That is probably where the leak is coming from.
Good luck.
Old May 15, 2012 | 12:36 PM
Harrys Kid's Avatar
Harrys Kid
5th Gear
Thanks For the help
To Leaky Rear axle
