Air pump running?
Old May 15, 2012 | 06:43 PM
legalins's Avatar
legalins
Default Air pump running?
I had the Vararam installed on my car then had it Dyno/road tuned. 2 days after when pulling into my garage I noticed my air pump was running? I thought this was only suppose to come on for a few minutes after start up. I went out a couple of hours after to start the car and the air pump did what it was suppose to and shut off after a few minutes. Any explanation why it would have been running after I had it out for a drive? Could it be reading the exhaust is to rich? I ahve no idea. This never happened before the Vararam and tuning.
It did not throw any codes either.
Thanks,
Rob
Old May 16, 2012 | 12:46 AM
baxsom's Avatar
baxsom
take it out.
Old May 16, 2012 | 01:28 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
How did you determine that the air pump was actually running?
Old May 16, 2012 | 01:38 AM
Lothar34's Avatar
Lothar34
Maybe the relay is stuck or maybe one of the wires got pinched and it's shorting to ground and staying powered on.
Old May 16, 2012 | 12:38 PM
legalins's Avatar
legalins
****, now I think it might have been the cooling fans. Will the Vararam make the cooling fans come on more often? It wasn't a hot day and the car was getting lots of air before i pulled into the garage.
Old May 16, 2012 | 08:19 PM
Quicksilver Vert 01
That's exactly what I was thinking too.....cooling fans!
You would be much less likely to hear the air pump running. It's fairly quiet, and should only be running for a short period after a cold start-up.
Old May 16, 2012 | 08:24 PM
lucky131969's Avatar
lucky131969
Originally Posted by Quicksilver Vert 01
.....and should only be running for a short period after a cold start-up.
Unless it fails the test routine, then it will run during normal driving....not just at start up.
Old May 16, 2012 | 08:30 PM
Quicksilver Vert 01
Very true, but the MIL should be illuminated after the second test routine failure. He didn't mention any codes being present.
Old May 16, 2012 | 09:06 PM
lucky131969
....provided his tuner did not set to not report..
Old May 16, 2012 | 09:23 PM
lionelhutz's Avatar
lionelhutz
Mine cycles on at various times at idle yet it passes the tests and doesn't throw any codes. No pump codes are disabled either. A bunch of people on this forum will say this can't happen and something must wrong yet they have no input on what it could be or how to test it.
Old May 17, 2012 | 11:18 AM
Quicksilver Vert 01
Using a scan tool, that can display real-time operational data, is the best way to test or diagnose problems in the AIR system.
The PCM monitors the pre-cat O2 sensor voltages in order to diagnose the AIR system.
A DTC will be set if: The AIR pump turns ON during closed loop operation and the O2 sensor voltage does not fall below 222 mV for 1.3 seconds.
Or
If the AIR pump turns ON during closed loop operation and the short-term fuel trim does not change more than a predetermined amount.
Old May 17, 2012 | 12:29 PM
lionelhutz's Avatar
lionelhutz
A scan tool - HPTuners for example? Everything looks fine, yet it still often cycles at idle and not just after a cold start.
At the end of the day, it's really not something I can be bothered to worry about any further.
Old May 17, 2012 | 08:10 PM
Quicksilver Vert 01
My AIR pump never runs after the initial start-up cycle is complete. I would be somewhat concerned if it cycled on and off after that period.
Old May 17, 2012 | 09:08 PM
lionelhutz's Avatar
lionelhutz
It passes the tests and no codes. The computer is commanding it on. So, how would I fix it when nothing seems to be broken?
Old May 18, 2012 | 08:49 AM
Quicksilver Vert 01
It may be just on the threshold of an off-spec operational parameter, where the PCM commands it on for another test.
Are you running a modified tune, or a stock tune?
Old May 24, 2012 | 08:14 AM
Quicksilver Vert 01
Have you confirmed that it was the cooling fans, and not the AIR system pump as you first thought?
To Air pump running?
