Right Rear Solenoid Circuit Open
Old May 17, 2012 | 01:04 PM
lougars's Avatar
lougars
Default Right Rear Solenoid Circuit Open
Hello, I have a dic error code C0594, which is the RR Solenoid circuit open. Where should I start with this error code on the car?
Old May 17, 2012 | 01:29 PM
KOZ's Avatar
KOZ
Ok here we go...
I assume you have a 2003-2004? Equipped with F55 suspension. (The switch on the console that says Tour/Sport)
This code may be the beginning of the end for your suspension, or a simple fix. Best case the connector came off the top of the shock for some unknown reason. Worst case the shock or controller has failed and require replacement. Have a look at the connector and harness and report back.
Old May 17, 2012 | 01:36 PM
lucky131969's Avatar
lucky131969
You do not state if the code is current or historical.
Old May 17, 2012 | 06:32 PM
lougars's Avatar
lougars
H c,
Old May 17, 2012 | 06:42 PM
lucky131969
H c,
Ok
Old May 18, 2012 | 09:52 PM
lougars's Avatar
lougars
Default Co594 HC
Pulled the connections off the shock and cleaned. Was not dirty.
Now I have a new error code, 10-PCM PP1280 HC.
Any ideas what to check futher?
Old May 18, 2012 | 09:54 PM
lougars's Avatar
lougars
All checked out and looked good, cleaned and re-connected back.
A new code has now appeared, 10-PCM P1280 HC,
Where do you think I should check now?
To Right Rear Solenoid Circuit Open
