Axle Back Exhaust Flange??
Old May 22, 2012 | 04:38 PM
EncinalZ06's Avatar
EncinalZ06
Cruising
Default Axle Back Exhaust Flange??
Going to install a new axle back (GHL) tonight and am wondering if there is a gasket at the flange where the axle back connects to the x-pipe? Just dont want to be stuck when im in the middle of the install and not have a gasket if one is needed.
Old May 22, 2012 | 05:14 PM
Last C5's Avatar
Last C5
Yes, there is.
Old May 22, 2012 | 05:22 PM
EncinalZ06's Avatar
EncinalZ06
Cruising
Thanks Last C5. Few people have told me know and I knew there had to be? Just did some searching and got the GM P/N. Local dealer had 2 available. If anyone needs it the P/N is 10276792.
I am surprised the exhaust system did not come with new gaskets?
Old May 22, 2012 | 05:43 PM
bumble-z's Avatar
bumble-z
They are quite re-usable.
Good luck.
Old May 23, 2012 | 02:46 AM
Last C5's Avatar
Last C5
That is odd. They usually throw in a couple of gaskets that are better than the GM part. But, as mentioned above they are reusable usually.
Old May 23, 2012 | 08:04 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Really? I haven't seen one yet.
Old May 23, 2012 | 08:30 AM
bumble-z's Avatar
bumble-z
I agree.
I haven't either.
Old May 23, 2012 | 09:56 AM
RonSSNova's Avatar
RonSSNova
The GM part has a metal ring in it.
I would think this is a rather uncommon flange, but maybe someone makes a dead soft copper type gasket?
Old May 23, 2012 | 08:53 PM
tstrobl1's Avatar
tstrobl1
My Magnaflow axle back system came with new flange gaskets.
Old May 23, 2012 | 08:55 PM
saxtonfwd's Avatar
saxtonfwd
I reused mine, little brittle on the outer edges so just put a bead of copper gasket
Old May 23, 2012 | 09:16 PM
corvette77's Avatar
corvette77
ROL gasket EG24685. It can be found at Autozone and Oreilly Auto Parts..
Old May 23, 2012 | 11:16 PM
m6 c5's Avatar
m6 c5
Ive had mine on and off more times than I can remember and I have 111000 miles on the car so far...
Old May 24, 2012 | 05:39 PM
Last C5's Avatar
Last C5
Originally Posted by bumble-z
I agree.
I haven't either.
Well, if you guys would quit buying cheap exhaust systems you would get the free gaskets. Just kidding. If you buy a complete system you usually get the gaskets and if you buy just the axle back it's a toss up.
To Axle Back Exhaust Flange??
