Reinstalling driver's side rear axle
Old May 26, 2012 | 02:14 PM
GCG's Avatar
GCG
Default Reinstalling driver's side rear axle
I just replaced the driver's side differential output shaft seal (the dreaded leak! ) and after reinstalling the axle I looked to the passenger's side to compare how they both sat against the differential. To my surprise the driver's side has a noticeable wider gap in relation to the passenger's.
Being afraid that I didn't properly sit it, I searched here and found this thread on the same matter. It looks that's the way it is, but the OP never came back to "close the case" one way or the other...
Here is a picture from that thread showing the same thing I'm seeing in my car:
Can someone confirm for me if this is how it's supposed to be, please?
Old May 26, 2012 | 02:58 PM
bumble-z's Avatar
bumble-z
Yes, you will be just fine .
As long as you are certain that the circlip was in it's notch/groove at the end of the differential out put shaft, prior to installing the axle assy.
Old May 26, 2012 | 05:01 PM
RonSSNova's Avatar
RonSSNova
I just finished installing both left and right side axles and both are in the same amount.
There is a receiver groove inside the splines of the axle that the circlip Bumble alluded to mates with.
I would try to gently pry the axle out. If it moves easily, the circlip is not into the groove I mentioned.
FWIW, I lubed the circlip and the inside of the axle splines prior to assembly. When sliding the axle home, it becomes it's own battering ram. Works great.
Ron
Old May 26, 2012 | 07:52 PM
GCG's Avatar
GCG
Yes, the circlip was there and I did lube it prior to assembly. I started the axle into the differential output shaft and using it as it's own "battering ram" went at it until it stopped, producing like a metal-to-metal sound. It was the kind of sound you would expect when you already reached the end of it.
To be honest I didn't try pulling because I thought it was clearly sat. After I finished assembling everything I checked the passenger's side and saw the difference and then is when I began wondering
I have a question, let's suppose an axle is missing a final little push to engage the circlip, would it finally clip in by just going around the block with the car?
Old May 26, 2012 | 09:09 PM
RonSSNova's Avatar
RonSSNova
I think you are fine then. That was the sound I got as well. I didn't even look at mine until your post.
Didn't mean to alarm you.
Who knows, maybe the axle isn't oem? Or maybe GM had some changes.
Given the miles on mine, and the amount of leakage and grunge, I'm sure they had never been out.
Ron
To Reinstalling driver's side rear axle
