Driver seat stuck in forward position
Old May 28, 2012 | 10:06 PM
NVR_L8's Avatar
NVR_L8
Default Driver seat stuck in forward position
I was driving down the free way at a constant speed of 65 and the drivers seat moved all the way to the forward position and now the controls will not work to adjust the seat. I checked the fuse and it was good but I changed it anyway. So the seat is stuck in the forward position even after replacing the fuse. Two days earlier the seat moved up an inch and then I adjusted it back and it did it again in about 10 minutes. This happened about 3 times on the way to work. When I returned back to the car after work the seat had moved all the way to the forward position while it was unattended without the key in the ignition. I drove the car back from work and it was fine. I took the car out this morning and drove about 10 minutes and the seat went to the forward position while driving and its stuck there now. It was a scary moment because the seat squeezed me in there so tight I had a hard time getting my foot off the gas and onto the break. I down shifted to 1st gear and coasted to the shoulder of the free way before I could get my foot on the break. Good thing it was 6 in the morning and there was no traffic on the road. I called a 4'10" friend to drive it home. Any suggestions on how to diagnose this problem would be greatly appreciated. I changed the radio about a month ago to a fancy Alpine blue tooth model but no problems till now just a thought.
