I just spent a big chunk of my day changing plugs and wires in my 2004 Corvette. I splurged and bought some super duper Pulstar Performance Series spark plugs and some fancy JBA PowerCables hoping they'd help my hp and fuel mileage.
Now that they're installed, my car is misfiring and running really rough, and the check engine light even came on and was flashing. I haven't had the code checked yet, since it's about 9:00 PM here and there aren't any parts stores open.
I don't see any arcing through any of the wires, and I'm pretty sure the wires are on securely. The plugs themselves were put on with anti-seize and with dielectric grease, and torqued to the 11 ft/lb specifications. In other words, everything was done right.
So any idea what I should do? Is there something I'm missing? I spent a big chunk of time changing the plugs, so I want to make sure I've got all my bases covered before I yank them out and start fresh.
Also, now that I've been cruising the interwebs, I've seen mixed reviews of the plugs that I put in. Could it be the plugs themselves?
Can't speak to the plugs you chose, as I've never heard of them. Hopefully, they come pre-gapped, or you gapped them appropriately. The flashing check engine light indicates a misfire, so I'm afraid it's up to you. You may have something as simple as a plug wire not on all the way (plug or coil side), or you may have cracked a plug during the install. You also have to be careful with the dielectric grease(since it is an insulator), only using a small amount on the plug side boot. Time to go over your work sir.
You can check the codes yourself. Do a search or look at the sticky note at the top of this section and follow the directions. It is easy to do. My guess is you have had a misfire and that triggered the CEL. Pull the codes and post them. Do not panic. You can always put the old plugs back in. Did you damage the old wires taking them off? Good Luck
Thanks for the quick help! I forgot to mention that I gapped the plugs to .040 as was recommended.
I didn't know, though, that the grease worked like an insulator, so maybe (and hopefully) it's as simple as a bad connection on the end of one of the plugs.
I checked the code that it threw, and it was a P0300 - a misfire - but I'll have to get an OBD scanner to tell me which cylinder it's on.
In either case, big thanks, and I'll have to continue on it tomorrow.
Yup... the DIC code scanner will not isolate an individual cylinder(s) missfire; it will just give you P0300. Get someone with a scan tool (most big autoparts store will do it for free) to scan your car and you'll know where to look. P0301 = cylinder 1 P0302 = cylinder 2 etc. Cylinders 1, 3, 5, 7 are on bank 1 (driver's side) with 1 toward the front of the car and 7 toward the rear. Cylinders 2, 4, 6, 8 are on bank 2 (passenger side) with 2 toward the front of the car and 8 toward the rear.
