I have a 1999 FRC I am going to add HUD ,Can anyone tell me if I will find that the cluster is HUD Ready .I did this on a 02 that I had and it was an easy install .I am acquiring the pieces now and don't want to change my original cluster .or purchase another if I don't have to . Any info appreciated ..
The HUD enabled clusters were installed beginning at an undetermined point during the 1999 production run. My 1999 was built in May and had the HUD cluster.
The only way to tell for sure is to look at the back of the cluster.
Reason: Can't believe everything you read.......
Looks like mine is Manufactured 10/98 , I don't want to change the original cluster because the car has only 28000 miles and I want to keep the integrity of the Milage etc. Thanks for your quick reply..
I've pulled dozens of '99's apart and have found the cluster HUD ready; if you have a 'solid' reference on the mid year data, please quote
It may be like the 1168 blocks used in 2001.......there were a few 00 blocks in the mix here and there
Nothing "solid" other than what I read here on CF when I was preparing to swap a HUD into my 99. It's an old thread - but here's a guy with a 99 who didn't have a HUD enabled cluster:
Not sure what the production date of his car was - but looks like some 99's came out without the HUD enabled cluster. Could be that the factory didn't have a clean cutoff.......
In any case - the only way to know for sure (on a 99) is to look at the back of the cluster.
I ordered my FRC in Jan '99 and HUD was not available as an option though I think GM installed HUD-ready IPCs pretty much across the board since when I later did my HUD conversion I found my HUD-ready IPC was already installed.
HUD did become available as an option on the FRCs before the end of the '99 production year.
Exactly, now we just added 15,000 troops into the 'potential' HUD cluster bracket
Don't believe all that is posted on boards
I agree. Which is why I recommended the OP check the back of his cluster to confirm which is present in his case. It's clear to me that not all 99 C5's came with the HUD enabled cluster. Without having a clear cutoff date - I can't think of any way other than visual examination to make certain.
I edited my post to make it clearer (I hope). Don't want to spread any misinformation.
Mine was produced mid March 99 and it did not have HUD enabled cluster. From what I remember when doing research couple years ago there ware cars produced in July that did not support HUD. Looks like the clusters were stored and released for installation without any particular order. As I know the only sure way it to physical check the top of the unit, good luck.
I agree that the only way to know in this case, pull it apart and check the top rear of the IPC for the ribbon cable connector there. If its there, you are ok to proceed. If not, you need an IPC
Possible. Though I ordered in Jan, my FRC was built on Mar 31st and, as I said earlier, I had the HUD-ready IPC in mine.
Too bad there's not a convenient way for non-HUD owners to check.
Originally Posted by Dale002
I have owned two 99 and both where early models. The HUD cluster already installed.
Most of the questions people have as it relates to HUD availability on the '99s, relate the FRC only. AFAIK, all coupays and verts have HUD compatible IPCs in large part due to it being an available option right from the beginning of the '99 model year.
HUD was not available as an option on FRCs (even if the car was ordered from the factory as mine was) until well into (Mar/Apr/May?) the 1999 model year. I AM however, open to the notion that the FRCs still possibly had HUD-ready IPCs installed from the beginning of their production run, even though the HUD RPO (UV6) itself, was NOT an available option and could NOT be ordered on them then.
My first 99 was a coupe so that would explain having the HUD cluster. My second one is an FRC built date 11/98 and it has the HUD cluster. However,r I'm not the original owner and it could have been change by the previous owner,but i doubt it since he was the original owner and 64 years old. You never know thou. I read awhile back that it was installed on all, even the FRC. I also used to know the reason why you couldn't order it on the FRC,but have gone over 50 since then and I have discarded all useless info from my brain to make room for other useless info.
Well, the FRC WAS a low-optioned car.
Amen on the discarded info, I do some of that myself.
Yes, they were trying to keep the price around 34k. When they were done it was less than 2k cheaper than a semi loaded coupe. I do remember that originally, they were suppose to have cloth seats and no power doors.
Yup, you're pretty much preaching to the choir here with me. I ordered mine new and waited for delivery, so I got really familiar with a lot of the differences in the RPO codes across body styles, etc. Hell, I even had the Mexican seats originally (they were both Man-well), Mexican HVAC (Man-well also), no lighted sun visor mirrors, no trunk lights, no under-hood light and it also didn't even have the auto lock/auto unlock feature (for the door locks), but put down 309hp bone stock.
That was 177K miles and a couple engines ago and still having fun.
Yes mine is a frc and was not optioned with a HUD but I did plan for that and bought all necessary parts like the cluster switch and monitor all in one shot but when I took it apart I did already have a HUD cluster in the car I just sold the cluster that I bought. And actually made a little money cause it was a low mileage unit so best bet tear it apart and see what you have worse case situation you have to buy a cluster and u can have it within 2 days off you don't mind the car sitting
