Gas brands & octane
I remember being on a Mobil tanker, taking on automobile gasoline at a Gulf refinery in Baton Rouge,
and off-loading it at a Shell tank farm.
Go figure............
:seeya
[Modified by steve badalamenti, 1:09 AM 5/24/2002]
Perhaps if my car was modified a bit, I'd see it??
Take care,
I thought if you used Union 76, your car wouldn't turn right! :D :D
I have a fellow I talk to that drives a fuel truck for Amoco/BP. He says most everybody gets the same base fuel from whatever regional refinery/ pipeline is in the area. So everybody starts off the same. But he, and most of the majors, have a very specific additive package (detergents) each adds that makes the gas unique. He also metioned he doesn't believe the cut rate guys add much of anything.
Now another conversation, with my cousin, who worked for Amoco in their retail marketing group. When fuel injection started to show up on several models of cars it was apparent everybody needed a better/different additive package. He said they did a lot of research and found, hands down, their people considered Techron the best. They also found it would be cheaper to buy Techron than try to work their way around some patents. So, at least, Amoco and Chevron have Techron which, at the time, was better than what else they found out there.
Putting those two converstaions together leads me to believe there is a different in gas. Certainly form the cut rate up, and even in what the majors use.
You mileage may vary...
I work for BP in the Chicago area and used to manage the gasoline distribution from the refineries to the marketing terminals for a couple of years. I am partial to Amoco gasoline (now owned by BP) as I know what goes into it, from the refinery side and the additive side - it is good stuff and "water white" (clear as water).
and not some "Mike's Cheap Gas" place :D
