Transmission noise - need technical drawings
It is a C5 corvette from 2000 with a manual 6-gears gearbox. I would need the complete drawings of gear box and differential.
Many Thanks.
PS : just to give you some back ground. I bought a stage 2 3.90 differential from RPM Transmissions and got noise after we mounted it. So we put back the old 3.42 differential which went fine. But after a few hundred miles, we have this noise again. So we are beginning to suspect a problem in the gearbox ...
