External Air Temp HVAC display
Jun 7, 2012 | 03:30 PM
St. Jude Donor '08
Hey guys,
I did some searching on the forum and couldnt find the answer I was looking for.
My HVAC display is showing -35 degress as the outside air temp. Unless hell froze over, It would never get that cold down here in texas
I also noticed that I can no longer engage my a/c compressor. Hiting the button makes the light flash, and return to off.
I believe the incorrect temp is also disableing traction control and abs??
Not sure what the problem is. The car is not throwing any codes.
Jun 7, 2012 | 05:20 PM
Time for a new external temperature sensor. Simple replacement and the part shouldn't be too expensive.
Jun 7, 2012 | 05:37 PM
St. Jude Donor '08
I will try that first. Will post this evening with the results.
Jun 7, 2012 | 05:52 PM
Quote:
Originally Posted by
DeadFred
Do yourself a favor, and inspect the connector first. It's very common for that particular one to become corroded.
Jun 7, 2012 | 05:53 PM
St. Jude Donor '08
if its corroded, should I try cleaning it before getting a new sensor?
Jun 7, 2012 | 05:57 PM
DeadFred
Yes.
Jun 7, 2012 | 06:01 PM
St. Jude Donor '08
Thanks Lucky. I will let you know what I find out after work.
Jun 7, 2012 | 06:20 PM
Also clean the nearby ground point.
After replacing the sensor, you will have to drive it around for 20 min or so to calibrate it.
