Replacing harmonic balancer help!!
Old Jun 7, 2012 | 09:47 PM
1SikVette's Avatar
01SikVette
Former Vendor
Default Replacing harmonic balancer help!!
Can anyone tell me if the fans and sway bar needs removed to pull the steering rack out of the way so I can replace the harmonic balancer?
Old Jun 7, 2012 | 10:14 PM
VetteNoob's Avatar
VetteNoob
If I remember correctly. Sway yes. Fans no but depending on your tools your puller might not fit easily or you could have a hard time getting a ratchet onto the pulley/installer.
Old Jun 7, 2012 | 11:12 PM
lionelhutz's Avatar
lionelhutz
Taking the swaybar off lets you reach the balancer easier from the bottom. I took my fans out but it could be done without pulling them. They're easy to take out.
Old Jun 28, 2012 | 03:56 PM
larryu's Avatar
larryu
I did not remove either and was able to remove and replace it as well as pin it. It may make life a little easier though the more stuff you can get out of the way. This is a PINA job.
Old Jun 28, 2012 | 04:10 PM
cdkcorvette7's Avatar
cdkcorvette7
I took the swaybar out and left the fans in...
To Replacing harmonic balancer help!!
