Tire Training
Old May 24, 2002 | 05:44 AM
RANGER69's Avatar
RANGER69
Default Tire Training
Anyone know how to program tire pressure sensors.... :confused:
Old May 24, 2002 | 08:00 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Tire Training (RANGER69)
Need a magnet..I use a contractor clean up magnet I purchased from Home Depot...place next to valve stem and do re-learn procedure as posted in tech tips...or in the manual...piece of cake....by the way magnet cost $9.99 :yesnod:
Old May 24, 2002 | 08:01 AM
pewter99's Avatar
pewter99
Default Re: Tire Training (pewter99)
Here it is from Tech Tips
) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the
display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in
order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool
(large magnet will do) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed
(if this takes more than 15 seconds, pull magnet back and try again, it will
give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the
following order as directed by the IPC messages:
-Learn R Front Tire
-Learn R Rear Tire
-Learn L Rear Tire
Programming can be canceled by turning ignition off, waiting 2 minutes with
no sensors being learned, finishing all 4 wheels or through the DIC.
If the programming is canceled with less than 4 sensors learned, it will only
accept the codes programmed up to that point.
Old May 25, 2002 | 05:30 AM
RANGER69's Avatar
RANGER69
Got it...Thanks a bunch.... :cheers:
Old May 25, 2002 | 08:15 AM
pewter99's Avatar
pewter99
Welcome...thats why we are here :seeya :flag
Old May 25, 2002 | 01:44 PM
White Star's Avatar
White Star
Hey just had to do this two nights ago. Those instructions above worked well (seen them posted before) The magnet only cost about $2.50.
I purchased mine at home depot the brand was the "Magnet Source" they are advertized as the strongest Ceramic Magnet. Two per package each one being 3/8" x 7/8" x 1-7/8" I just let them connect on their side and layed them vertically against the stem.
The horn was sounding at about 4 - 5 seconds
Old May 26, 2002 | 03:40 AM
RANGER69's Avatar
RANGER69
Default Re: Tire Training (White Star)
Yeah just finished tire training, worked great ...Now anyone know how to stop valve stems from slow leak...both front stems are losing air... :sad:
Old Jun 4, 2002 | 07:32 PM
comptonb's Avatar
comptonb
Cruising
I have '99 that does not have wheels in correct order, RF is really LR, RR is really RF, and LR is really RR. New tires were put on car before I bought it and wheels did not get put back on correct corner. The front tires are different than the rear tires so I can not just do corner swapping. I have friend with '98 and hers are mismatched by having wheels just swapped front to back. The tire training works ok by just finding wheel that beeps regardless of what DIC indicates except for real LR wheel. Neither of our LR
wheels will beep (mine is on RF and hers is on LF). I will probably get the tires correctly mounted and get the wheels back on the correct corners but any suggestions in the meantime? Thanks
To Tire Training
