Molding around windshield - part numbers needed
Old Jun 9, 2012 | 06:02 PM
j84buick's Avatar
j84buick
Default Molding around windshield - part numbers needed
Anyone have them? I am talking about the molding that is required to be replaced when replacing the windshield.
Old Jun 9, 2012 | 06:10 PM
j84buick's Avatar
j84buick
Sorry.... meant to post in C5 general.
Old Jun 10, 2012 | 11:04 AM
tstrobl1's Avatar
tstrobl1
Check with GM Partshouse or Mid America Motorworks. The bad thing is no aftermarket companies make this piece of weatherstrip. It will cost you about $450 for just the weatherstrip.
Old Jun 10, 2012 | 03:43 PM
LoneStarFRC's Avatar
LoneStarFRC
Are you referring to item #21 or #18?
#21 10299765 - Shows to be "1420mm" in length (56 1/4"~)
#18 10333466 - Weatherstrip (with W/S upper reveal molding)
Old Jun 10, 2012 | 05:36 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referral. I'd certainly be happy to help you out.
Old Jun 13, 2012 | 08:32 AM
j84buick's Avatar
j84buick
Not exactly sure. Is #18 the weatherstrip you need to replace when replacing a windshield? I had heard the reveal molding needs to be replaced. I assumed it is the molding around the outside of the windshield.
Old Jun 13, 2012 | 10:53 AM
LoneStarFRC
No, #18 is the main, or primary, weatherstripping that each door glass seals against and also your removable roof panel as well. It is all one piece and expensive, but it only needs to be replaced if it is damaged, torn, etc.
A reputable car glass replacement company can assist you. They do this for a living and can tell you specifically what they would replace when R&Ring a windshield. I would ask them if they are proficient in replacing C5 Corvette windshields or if they have done this procedure before and if possible, check their reputation where you are.
Old Mar 27, 2013 | 10:37 PM
Chinookmtp's Avatar
Chinookmtp
is number 18 used in the z06 or FRC? it only shows up for the vert and coupe, hot rod shop is putting my windshield back in after painting.
Old Mar 28, 2013 | 01:26 PM
LoneStarFRC
No, it is not. GM part #10427732 is used across the top of the glass on Hardtops (only) during windshield replacement.
HTH
Old Mar 31, 2013 | 07:12 PM
Chinookmtp's Avatar
Chinookmtp
HTH
Thanks, that will save me over 450.00 in parts. I can't believe the price of some of the weatherstriping for this vehicle...It's been completely disassembled at a hot rod shop for a paint job..
To Molding around windshield - part numbers needed
