To make the cigarette lighter switched with the key you pull fuse 7 and then connect the yellow and orange wires on the 3-wire connector that is in the passenger footwell. It should be tucked in there with a taped off pigtail. If I recall it's to the left side by the body control module. Make sure you don't install fuse 7 again.
You could make the console plug switched by pulling fuse 1 and jumpering the dead side of fuse 1 to the dead side of fuse 7. You could use 2 blade connectors on the ends of a piece of wire. Check for the dead side with the key off.
