Leaky fuel filter on '98 C5
Old May 24, 2002 | 01:19 PM
DefDog's Avatar
DefDog
Default Leaky fuel filter on '98 C5
Just was informed that my fuel filter at the tank is leaking. The Vette only has 12000 miles on it. Bought it month and half ago at 9800 miles, have done nothing to fuel line or filters or any mods close to the problem. Is there any reason why a leaky fuel filter would occur this soon? Did I get a bad deal at the dealership? Was told the warranty will not cover it...I got the extended warranty. Bullpoopie or what?! Please advise. :smash: :bs
Old May 24, 2002 | 02:22 PM
lotzahp's Avatar
lotzahp
Default Re: Leaky fuel filter on '98 C5 (DefDog)
maybe the former owner had something done to it
ask the dealer to pull the service history for the car (some claim they cannot get history for cars they don't service, but I've heard they can).
The repair shouldn't be too expensive though: less than $100.
Old May 24, 2002 | 05:17 PM
JCR's Avatar
JCR
Default Re: Leaky fuel filter on '98 C5 (lotzahp)
Is it the external filter, or the internal sock? If its the external should be about 12.00 .. If that one is leaking, beware of a fire.. This is close to the exhaust pipes. The other ones are inside the tank and have a hard time with that one leaking. The car has low usage and things tend to dry out if not used..
Old May 24, 2002 | 05:33 PM
DefDog's Avatar
DefDog
Default Re: Leaky fuel filter on '98 C5 (JCR)
Fuel was leaking under the car, beads hanging underside, drivers side about 4-5 inches in. I believe it is the external. Was told clips were claimed to be problem, running from filter. Something poked a whole in the line, as claimed by mech. Costs under $100. I asked about the internal sock, reply was no. $12.00????? Are you sure? Did I just get reamed? :eek:
Old May 24, 2002 | 05:49 PM
JCR's Avatar
JCR
external fuel filter is 12.00 at parts store. i just got one ;ac delco too. you got ripped plain and simple. if they had to replace the fuel line then you could expect additional costs. don't know how that punture ???could happen though .Any one ever change out the exhaust?
Old May 24, 2002 | 06:46 PM
Sam Lin's Avatar
Sam Lin
If someone tried to change the fuel filter without the proper quick disconnect removal tools, it could very easily have holed the line and damaged it severely.
As stated, new filter is not expensive, and the QD disconnect removal tools are available at any auto parts store for under 10 bucks. Then find the writeup on the net for the replacement (I think there's one on this forum) and do the work yourself, it's not hard.
Sam
Old May 24, 2002 | 07:14 PM
DefDog's Avatar
DefDog
Default Re: Leaky fuel filter on '98 C5 (Sam Lin)
Thanx, y'all. Been a lot of help. :cheers:
To Leaky fuel filter on '98 C5
