check engine light
Old Jun 12, 2012 | 05:51 PM
antjr2's Avatar
antjr2
Default check engine light
I have a '97 c5 corvette with roughly around 120k miles. When I step on the gas pedal from a dead stop my check engine light comes on with no codes showing at all. It only comes on when I step on the gas pedal hard. Just cruising around and stuff it never comes on. When I park the car for a while the check engine light eventually goes away. The only mods I have is straight pipes by the way. Any help is appreciated thanks!!!
Old Jun 12, 2012 | 06:17 PM
ZeeOSix's Avatar
ZeeOSix
Can't recall exactly ... but thought the Check Engine light comes on to indicate a mis-fire. Could be you're getting a mis-fire during hard acceleration.
Old Jun 12, 2012 | 06:21 PM
lucky131969's Avatar
lucky131969
Originally Posted by ZeeOSix
Can't recall exactly ... but thought the Check Engine light comes on to indicate a mis-fire. .
.....specifically...a "flashing" check engine light.
Old Jun 12, 2012 | 06:52 PM
antjr2's Avatar
antjr2
Oh ok. I appreciate that
Old Jun 12, 2012 | 07:07 PM
antjr2's Avatar
antjr2
No there is no "flashing" check engine light. When the check engine light is lit there are no codes being displayed. I can't pull any codes because none of my dic buttons are working. Hasn't worked in years.
Old Jun 12, 2012 | 07:35 PM
ZeeOSix's Avatar
ZeeOSix
So that's what 8VETTE7 was eluding to. Sounds like you didn't pull codes ... just didn't see any message on the DIC display.
Guess you could whip by Autozone or similar parts store and have them use their OBDII scanner to get codes if you can't do it from the DIC.
Old Jun 12, 2012 | 08:11 PM
antjr2's Avatar
antjr2
Oh ok. Well thank you very much. I will take by there asap. Thanks again guys for the info!!!!!
To check engine light
