I know there are thousands of brake pad threads, but I can't seem to find one that addresses this topic: is there a significant difference in stopping power between the Hawk and the GM ceramic pads.
I've already decided on ceramic pads because I DD my car and as much as I'd love it to, it will probably never see the track with me behind the wheel. So now I'm torn between the trusted Hawk ceramic, or the GM.
Does anyone know the difference between the compounds used in these two pads. I'm buying a set by the end of the week, so input is greatly appreciated.
I tried the GM ceramics and hated them. Took them out after a couple hundred miles..I ran HAWK HPS and they were good pads but dusted a ton and the dust actually started pitting the barrels on my CCW Classics.
I now run Carbotech 1521's. Great pad, no ceramic downside and what little dust there is is pale gray AND non-corrosive. Do some research on Carbotech.
Fair enough. I am looking at ceramic pads afterall, might as well compare the 3 big ones. So now we're talking GM Ceramic vs. Hawk Ceramic vs. Carbotech Ceramic. I know the GM ceramics will be the least expensive, but what am I giving up?
Thanks WKMCD. Always nice to know there's another Vette nut close by!
Thanks as always,
John
Take a look at the Carbotech 1521 pad.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
F $148 R $128 Less 5% Let me know if I can help you.
I run the GM Ceramics and I do feel like they dust allot. Haven't had experience with the Hawks, but hear good things. That's what Id try next. Ceramic to ceramic is not going to give you a difference in braking. Its the same material in the same braking system. Just my opinion anyway..
That's a couple points for the GM ceramics if you trust them on your 700hp beast Matt!
Nuke, what wheels do you have? I just realized that ceramic pad dust is white, and my wheels are black.... Not a huge deal, just something I didn't think about until now.
I figured that the ceramic compounds would be similar, just wasn't sure. I like the sound of the carbotech's, but they also seem to be the most expensive of the 3 choices.
Carbotech Performance Brakes™, the world leader in Ceramic friction materials™. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry.
I have the OEM Magnesium wheels that are that sort of bronze color. They show allot of dust for some reason. But the pads are great, last long, and are quiet.
Those Carbotech's sound worth looking into. Ill consider them when it comes time for a change.
Very timely thread for me as I'm about to switch pads. I have EradiSpeed Plus 2 rotors and 18/19 wheels and about 405 HP. I like to go deep and brake hard.
I've been trying to decide between Hawk HFS street pads and Hawk ceramics.
I'll now include Carbotechs in the search since total non-corrosive dust rings my bell with an expensive set of chromes on board. Still not sold completely on ceramics though since I frequently push the car hard on hilly roads.
I'm curious to hear why you didn't like the GM ceramic pads.
They lasked initial bite, took more pressure on the pedal and just felt horrible on the Eradispeed Plus 2's I run. Sort of a grinding" feeling in the pedal. The Carbotech's don't have any of that and feel just like a conventional pad.
