Fan 2 keeps blowing fuses.
Old Jun 14, 2012 | 12:24 AM
Joer350's Avatar
Joer350
Default Fan 2 keeps blowing fuses.
I have a 2003 6 speed, while driving in traffic I had noticed my temperature reaching 240's. The temperature never dropped back down. I then noticed the maxifuse for fan 2 was blown. Replaced the fuse then day later same deal. This time it kept blowing the fuses once the fan started on. I then switched the fans with my other vette to see if it was the fans. It still keeps blowing the 30 amp maxifuse. I have also checked the relays and the look ok any advice would be appreciated.
Old Jun 14, 2012 | 07:49 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Did you try using the fan relays from your other Vette?
Old Jun 14, 2012 | 11:33 AM
Joer350's Avatar
Joer350
Wow 8VETTE7 thanks for the diagram that is very helpful. Prior tho this I did swap the ignition relay and fan 2 but it still continued to burn the fuses. I will go ahead and swap the relays with the other vette and see what happens.
Old Jun 14, 2012 | 01:46 PM
Joer350's Avatar
Joer350
I got fan 2 to work but only at temp being over 230. Once it drops the temp under 220 it shuts down while fan 1 keeps working.
Old Jun 14, 2012 | 02:14 PM
Quicksilver Vert 01
Both fans should ALWAYS run together.
In the Fan 1 mode, both fans are connected is series and should be running at low speed.
In the Fan 2 mode, both fans are connected in parallel and should be running at high speed.
Old Jun 14, 2012 | 07:37 PM
Joer350's Avatar
Joer350
Fan 2 is working now without blowing a fuse, I have noticed fan 2 only comes on when temp is above 235 then once temp drops it shuts off while fan 1 keeps going. I still have not seen both fans kick in at low speeds. I will just replace the relays to be on the safe side as they are not blowing no more Maxifuses.
Old Jun 14, 2012 | 11:38 PM
lionelhutz's Avatar
lionelhutz
Yes, from your description either relay 44 is stuck on or the wiring or fan for what you're calling cooling fan #2 or right fan on the schematic is causing a higher current draw to ground. It's possible the wire is damaged but not shorted, not too likely but possible. I could definately see this happening if the motor for that fan is failing.
To Fan 2 keeps blowing fuses.
