Coated headers worth it ?
Old Jun 15, 2012 | 02:51 PM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Default Coated headers worth it ?
Thinking of getting Kook headers and x-pipe with hi-flow cats for my 2000 Vette.
The motor is tricked up to put out 400hp, and more with the juice.
I am debating whether to have the headers coated or not..it's an additional 300 bucks.
I know the coating will keep the engine compartment cooler and keep the heat inside the header resulting in a fraction more hp.
Antbody have any strong opinions on this ?
777
Old Jun 15, 2012 | 03:16 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
777
Yes!!!! I cooked through plug wires like crazy until I had mine coated...safe yourself having to pull the hassle and get them done right off the bat.
Old Jun 15, 2012 | 07:39 PM
tiojames's Avatar
tiojames
Certainly worth it. You can buy steel headers coated inside and out for less than SS and have all the benefits that come with the ceramic costing. Mine have been on for 7 years, no leaks, and still look brand new.
Old Jun 15, 2012 | 07:58 PM
Paul 75 L82's Avatar
Paul 75 L82
I would never have uncoated headers. They are hot and look terrible.
Old Jun 15, 2012 | 08:38 PM
SCALLOPED91's Avatar
SCALLOPED91
If you enjoy your car and want to keep it nice, do not give any consideration to uncoated headers. There are so many draw backs to uncoated headers like, over heating tranny fluids, intensifying under Hood temps, turning into rusty crap, and they catch stuff on fire a lot easier. Keep the high exhaust temps in the exhaust not in your ride.
Old Jun 15, 2012 | 08:54 PM
brrymnvette's Avatar
brrymnvette
Swaintech coating is amazing. I've never seen anything work so well. I've touched a set of headers after 3 straight hours of driving that had their coatings.
Old Jun 15, 2012 | 09:10 PM
Bob Chapman's Avatar
Bob Chapman
I have Stainless Works headers on my 02 which puts out 400 rear axle HP. I use the stock plug heat protectors and have never had a problem with plug wires. The 304 stainless steel headers have developed an nice patina even though you can barely see them from the engine compartment. I would not spend money to coat headers unless you are really concerned about appearance and heat.
Old Jun 15, 2012 | 09:15 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
I can post pics of cars uncoated and coated. The damage to the wire harness over time is accelerated without coating. I recommend coating to everyone if they can afford it. The wire loom etc will become brittle. At least here in Texas its hot!
Old Jun 16, 2012 | 11:48 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I was wondering about their coatings, I've seen their ads in mags but you never here about it on the Forum. How does it rate against Jet Hot coatings and the others.
Old Jun 16, 2012 | 08:36 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
TOP 10 header debate: coat or no coat
I listen to the same people that make the LT headers for Ford FR500, Viper ACRx, Challenger Drag Pak, and Copo Camaro; they don't suggest coating them
Shoot a coated header with IR temp gun and compare to a bare SS header
Old Jun 16, 2012 | 09:54 PM
stevebz06's Avatar
stevebz06
Well, that answers THAT question!
Old Jun 17, 2012 | 01:25 AM
Mike94ZLT1's Avatar
Mike94ZLT1
For those of us without IR temp guns, what happens?
Old Jun 17, 2012 | 07:39 AM
basicstrategy777
I appreciate the responses.....but I am still confused as to if coating the headers has any benefit and worth doing.
Is it a 'chicken soup' thing or are there 'for sure' benefits.
777
Old Jun 17, 2012 | 09:38 AM
SteveDoten's Avatar
SteveDoten
Nino, call the crew at www.americanracingheaders.com and get the info direct
They have done the research and give you the no BS answer
It's needed on lower cost/quality mild steel headers which will rust away in a few years here in the NE if driven year round; not in snow, but year round
Old Jun 17, 2012 | 10:17 AM
basicstrategy777
Thax Steve...will follow up.
777
Old Jun 17, 2012 | 12:21 PM
SteveDoten's Avatar
SteveDoten
Mike, you make AN lines, you gotta have a temp gun bud
Old Jun 17, 2012 | 09:22 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Ha! It's on my list of "wants" but not positive I need it yet!
To Coated headers worth it ?
Old Jun 18, 2012 | 02:10 PM
basicstrategy777
Steve....called bith AR and Kooks and neither were beating the drum for coating headers.....they were both cool to the idea and basically said save your money.
777
Old Jun 19, 2012 | 01:41 PM
basicstrategy777
It appears that underhood temps are reduced.... see here:http://www.centuryperformance.com/ex...e-spg-138.html
Strictly speaking, the coating is not necessary but I'll probably do it anyway. I like the idea of cooler underhood temps and a tad more hp....10°F reduction in intake air temperature provides a 1% increase in horsepower. A 30°F reduction equates to a 3% horsepower increase........
Toss up if you want to spend an additional 2/300 dollars. Your call.
777
Old Jun 19, 2012 | 03:34 PM
LoneStarFRC's Avatar
LoneStarFRC
Like Steve said, mild steel: definitely (outstanding corrosion protection), stainless steel: doesn't hurt, but optional
