fuel pressure regulator location?
Locations:
1st c5s: FPR on fuel rail
2nd: in the fuel tank?
3rd: in line, a fuel filter/FPR combo installed on frame rail under car.
So, I have a 2002, so it should be the 3rd choice....BUT, I have a FPR on the fuel rail crossover line over my ls6 intake. Im guessing someone swapped this FPR (or added it
) to remove this restriction on the stock later model c5's. I wanna make sure, as I've heard that no matter what you throw at a fuel issue (bigger pump, injectors, hotwire kit, boost a pump, etc), it may not help or be necessary until the stock restriction is removed (restrictive FPR not mounted on fuel rail)
Thanks for any input y'all have
Locations:
You either have an aftermarket FPR, someone installed a 97-98 rail, or you are assumming what you see on your 2002 rail is a FPR, and did not even bother to look at the frame rail location for the filter/regulator.
No, I haven't looked under the frame rail yet.....anything doing with the bottom of this car seems to get held off until I have a few good hours to work with it and other things to service under there. And to think I wanna lower another inch.
If you only have 1 line going to the fuel rail what your looking at is a pulse damper not a regulator.
I only have one fuel line to the rail, so it must be a pulse damper.....which is I term I've never heard before.
thanks for the input guys. I had to goggle pulse damper
