Shock Recommendation
Old Jun 23, 2012 | 07:48 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Originally Posted by kris6868
'04 Z06 shocks are great too
I changed my 02's to the 04's and the ride quality improved a bit on the street but the handeling on the track improved quite a bit. I had a choice of the bilstiens sports or the 04's, and after a lot of reasearch, I went with the 04's.
Old Jun 24, 2012 | 04:03 PM
grillsja's Avatar
grillsja
Originally Posted by emullick
I have a set of new Bilsteins and have removed the attaching hardware of the right front, but the shock won't come out without compressing it. How to compress it?
2 big long tie wraps...you'll figure it out
Old Jun 24, 2012 | 04:05 PM
grillsja's Avatar
grillsja
2012 c6z06 are just as good and a whole lot cheaper...gmparts warehouse...I'm fellin like the AFLAC duck!
Old Jun 24, 2012 | 04:27 PM
fendermender's Avatar
fendermender
Originally Posted by lionelhutz
Shocks for better handling and shocks that provide a soft comfy ride are kind of in contrast with each other. I think Monroe makes a replacement shock that would keep the soft ride but they likely wouldn't help in the handling.
And I'm looking to keep the soft ride more than anything. Most secondary roads in PA are bumpy as hell. Monroe makes a Sensatrac. Rock has em for 33 a piece. Wondering if anyone ever tried them. I'm OK with the F45 as is on tour but the creaking and squeaking is bugging me.
Old Jun 24, 2012 | 08:29 PM
flynhi's Avatar
flynhi
I tried a set of Sensatracs on my Suburban and they were fine for about 20k miles then deteriorated rapidly.
Old Jun 25, 2012 | 08:42 AM
fendermender
I guess you get what you pay for.
Old Jun 25, 2012 | 08:45 AM
flynhi's Avatar
flynhi
Or less.......
Old Jun 25, 2012 | 09:57 AM
lionelhutz's Avatar
lionelhutz
Ever consider that the creaking and groaning might not be the shocks but the swaybar bushings or end links?
Old Jun 25, 2012 | 11:09 AM
flynhi's Avatar
flynhi
I had this problem and the end links had to be tightened beyond torque specs to stop it.
Old Jun 25, 2012 | 11:24 AM
fendermender
I lubed the bushings real good with silicone grease when it was apart. The end links look fine with no torn boots ect. I guess I can have another look and put a wrench on everything.
I was suspecting the shocks from the reading here. Several threads where people chased this chassis squeak, replacing sway bar bushings, a-arm bushings and all came back to the F45 shocks. Most had fewer miles than mine at 72k. Only notice this at slow speeds over good size bumps.
Old Jun 25, 2012 | 11:39 AM
Pfadt Racing's Avatar
Pfadt Racing
Originally Posted by Kooker01Z
Go for Pfadt, the Johnny O'Connell shock/sway bar package. Just put it on my 01 z06 and absolutely amazing (the car is my daily driver). I have no problem guaranteeing that you will love this package. It's $1000 for the whole pack (bars, shocks, metal end links and poly bushings) and 100% worth every penny.
Thanks Kooker01Z! We really do love the entire Johnny O package as it replaces most of the main wear items on your C5's suspension.
We would definitely recommend the Johnny O'Connell package for you. It's going to provide levels of performance that just can't be matched by swapping in OEM hardware.
Old Jun 25, 2012 | 06:59 PM
rwlc5's Avatar
rwlc5
Does anyone have any experience with the Koni FSD shocks?
Old Jun 27, 2012 | 09:56 PM
  #33
KingTut's Avatar
KingTut
Default C6 Z51 shocks
First for cornering - the sway bars are the way to go. Get some used Z06 bars.
For shocks, I have gone through about 3 different types and they all were wat to stiff for me. Finally I got a set of C6 Z51 shocks for under $100 with 7K miles and they are real nice. Just a bit stiffer but not anywhere near most of the others.
You probably can find a set of stock shocks that someone took off early for cheap bucks if you want to stay stock. Otherwise, these are probably the next step up the stiffness ladder.
Old Jun 27, 2012 | 10:01 PM
  #34
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
C5 z06 or c6 z06//c6 alittle better. For the money look for low milage forum ones. East change out. Alot of things change out on suspension. C5 z06 & c6 z06 / c6 a little tougher. Why pay alot more.
Old Jun 28, 2012 | 12:26 PM
  #35
Flatlander's Avatar
Flatlander
I put Koni FSD shocks on my '02 Z06. Smoothed out bumpy roads
and improved track handling. Only downside- very expensive.
I love them.
