C5 Dash Cluster
Old May 25, 2002 | 02:38 PM
FirebirdWS62K1's Avatar
FirebirdWS62K1
3rd Gear
Default C5 Dash Cluster
I have just purchased a 2001 C5 Convert. It was a Canadian car and has the metric guages. Is it hard to switch them over to US gauges? What do I need and does the ECM need to be reprogrammed? Is there a replacement ECM or is it something else that calculates the temp and oil pressure? The guages are kind of cool thought the speed-o-meter goes to 300MPH. :chevy
Old May 25, 2002 | 03:15 PM
Viprklr's Avatar
Viprklr
Default Re: C5 Dash Cluster (FirebirdWS62K1)
Not too hard if you have the right tools and a little patience. Check out this link, it will be helpful:
http://www.vetteaccessories.com/gaug...stallation.htm
Once the new guages are installed can't you just toggle to get out of metric mode? I can toggle back and forth on my car?!?!? :confused:
Good luck! :cheers:
Old May 26, 2002 | 02:44 PM
FirebirdWS62K1
3rd Gear
Default Re: C5 Dash Cluster (Viprklr)
Thanks a lot for the link. Yeah I can toggle to get to metric/US but I didn't know if I needed a different ECM because the car was made for Canada. If it's just the guages then are the factory guages a good replacement Idea or should I get some kind of aftermarket guages?
Old May 27, 2002 | 08:29 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
why do you want to replace the gauges if you can toggle to US mode?
the 300 MPH speedometer looks really cool!
I may be intrested in trading you? :cheers:
Old May 28, 2002 | 03:32 AM
redcorvette1995's Avatar
redcorvette1995
Hi from a Canadian,
There is no difference other than the cluster, I would
just toggle between, metric and US. The 300 MPH spedo
is Impressive.
To C5 Dash Cluster
