Compression check PSI for forged, low compression motor.
Does anyone know what PSI each cylinder should be on a compression check for a forged 347 lower compression (9.5:1) motor with a mild blower cam, cold, with the throttle plate closed should be?
This is a buddies car and his readings were only a few PSI off but all in the lower 100's. His leak down numbers were good (7-13%). Thanks.
