Catch can install
Old Jun 24, 2012 | 07:52 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default Catch can install
I have a catch can installed and I was told by a mechanic it was hooked up wrong can someone chime in with the correct routing for a 04 so I can verify I have my lines correct.
[IMG][/IMG]
Old Jun 25, 2012 | 07:34 AM
01_torch_red_vette's Avatar
01_torch_red_vette
did you remove your pcv valve from the system completely?
Old Jun 25, 2012 | 08:07 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Yes
Old Jun 27, 2012 | 05:57 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Old Jun 27, 2012 | 06:52 PM
VetteNoob's Avatar
VetteNoob
http://www.ls1tech.com/forums/11059703-post70.html
Old Jun 27, 2012 | 07:07 PM
Cybermind's Avatar
Cybermind
Your mechanic is right. You should not have removed your PCV. You need to search out the right instructions for your LS engine setup.
Old Jul 2, 2012 | 09:49 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
http://forums.corvetteforum.com/c5-g...ve-or-not.html
Old Jul 2, 2012 | 09:50 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Thanks for that link. As per this diagram I do have my catch can installed correctly...
Old Jul 2, 2012 | 09:52 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
In regards to this post with the information I have found what I thought was the complete system... was only the hoses out of the vally cover and to the TB. So I thought I removed the system when I removed those hoses.
Old Jul 3, 2012 | 12:19 AM
ALLEGRO's Avatar
ALLEGRO
Old Jul 3, 2012 | 06:23 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Originally Posted by ALLEGRO
If you read the above statements I DID NOT REMOVE MY PCV!!! It is internal in the LS6 intake my mechanic friend did not know this either. He was questioning the routing of the lines I have hooked up.
Old Jul 3, 2012 | 12:40 PM
NukeC5's Avatar
NukeC5
If your PCV valve is under the intake, it looks to be installed correctly. Just monitor it and see if the can is collecting oil. If so, and you dont have any wierd pressure readings or problems, it should be fine.
Old Jul 3, 2012 | 12:54 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Thank you for real feedback! I have a lean code bank 1 and I am trying to chace down the issue so vacuum pressure was the first stop in my troubleshooting.
Old Jul 3, 2012 | 01:50 PM
ALLEGRO's Avatar
ALLEGRO
I am not doubting you or your work, but I too have the LS6 intake and the valve is on the passenger side of the TB.
Hope you chase the leak, will lead to an erratic idle and performance.
To Catch can install
