A4 TRANNY ???
Old May 26, 2002 | 03:27 AM
blue98coupe's Avatar
blue98coupe
Default A4 TRANNY ???
When using synthetic fluid do you need to add limited slip additive to A4 ???
Old May 26, 2002 | 08:54 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: A4 TRANNY ??? (blue98coupe)
Hi there,
As long as you are using a Dexron 3 designation, NO fluid modifier is needed.
Besttoyou, c4c5 :crazy:
Old May 26, 2002 | 12:52 PM
IMQUIK's Avatar
IMQUIK
Use Amsoil Synthetic ATF and you will be all :D :D :D :D :D
Take 12 quarts,and have it pumped in. Get it ALL out. :smash:
Limited slip is rear end lingo,not transmission. :nonod:
[Modified by tshac, 11:54 AM 5/26/2002]
Old May 27, 2002 | 10:13 AM
VetteVert's Avatar
VetteVert
Default Re: A4 TRANNY ??? (tshac)
The limited slip addative is recommended for many trasmissions (albeit usually manuals). IIRC, it aids in synchro mesh. Probably where the question comes form :)
VV
Old May 27, 2002 | 09:03 PM
IMQUIK's Avatar
IMQUIK
Default Re: A4 TRANNY ??? (VetteVert)
The topic is "A4 TRANNY" Who said manual? No A4 Tranny will take friction modifier :smash:
Old May 27, 2002 | 11:23 PM
Mike Mercury's Avatar
Mike Mercury
I thought the limited slip additive was for the carrier, not the automatic transmission?
To A4 TRANNY ???
