Which OIL filter to use??
Old May 26, 2002 | 09:53 AM
BLKBLUR's Avatar
BLKBLUR
Default Which OIL filter to use??
Need to change the oil soon. I don't know which oil filter to use. I've always used Fram or Purolaters. With the vette, I thinking either Mobil One, or
K & N. I've heard good about both, and the Mobil 1 is a few dollars more.
The AC Delco (PF44) is about $6, but doesn't seem much better than the Fram or Purolater. Any advice is appreciated. :)
Old May 26, 2002 | 11:15 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Which OIL filter to use?? (Y2K2C5)
UPF44 or PF44 <<<< workin good for me... :yesnod:
Old May 26, 2002 | 11:25 AM
RoliO's Avatar
RoliO
Default Re: Which OIL filter to use?? (pewter99)
Me too. :cheers:
Old May 26, 2002 | 11:39 AM
boblackhardtop's Avatar
boblackhardtop
UPF 44 or Mobil 1, Fram are crappy filters these days.
Old May 26, 2002 | 12:43 PM
RHILL's Avatar
RHILL
Default Re: Which OIL filter to use?? (boblackhardtop)
Doesn't really matter when it's only on there for 3K my oil is hardly dark when I dump it. Fram filters are not crappy filters. There filters are better today then they have ever been. Don't buy into all the snakeoil claims that your engine will last longer if you use a 15.00 filter over a 6.00 one that's total BS.
I think the key is to change the oil and filter every 3K. I have a daily driver C4 that I've owned since new, that has almost 190K on it. I just replaced the oil pan and valve cover gaskets a few weeks ago and there was no build up what so ever and that car has only had Mobil 1 with Fram filters since new.
Old May 26, 2002 | 12:59 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Mobil 1 or UPF44. Same filter element, different packaging. If you find one cheaper than the other, buy that one.
Can't go wrong with either.
Old May 26, 2002 | 04:45 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
Default Re: Which OIL filter to use?? (RHILL)
Fram IS a crappy filter. I have cut new filters apart to see how they are made and Fram is the worst.
Old May 26, 2002 | 04:53 PM
CliffB-99's Avatar
CliffB-99
I cant ever seem to find the Delco Ultragaurd UPF 44, so I always buy the Mobile 1 Filter at Autozone. :chevy :flag
Old May 26, 2002 | 08:30 PM
nevadacoin's Avatar
nevadacoin
Default Re: Which OIL filter to use?? (CliffB-99)
Delco Ultraguard UPF 44 :yesnod: :yesnod: :yesnod:
Old May 26, 2002 | 09:59 PM
90 droptop's Avatar
90 droptop
I got my PF44 from K-Mart for $1.00, so I bought a dozen.
Old May 27, 2002 | 12:00 AM
BarryR's Avatar
BarryR
The AC Delco UPF-44 and the Mobil 1 oil filters seem to be the same. The UPF-44 has media that filters out partices in the 8 to 10 micron range. The regular AC Delco PF-44 filter only goes down to the 25 to 40 micron range.
The UPF-44 filters are available from forum vendors (about $8-9 each).
Good luck.
Old May 27, 2002 | 07:31 AM
IMQUIK's Avatar
IMQUIK
Amsoil SDF-32 :smash:
Old May 27, 2002 | 08:33 AM
EHS's Avatar
EHS
Default Re: Which OIL filter to use?? (tshac)
Anyone made by a reputable manufacturer that fits. :smash:
Old May 27, 2002 | 09:01 AM
Tom/99's Avatar
Tom/99
I have been using a Delco PF-44 oil filter.
To Which OIL filter to use??
