corvette dies when put in gear
Old Jul 3, 2012 | 06:21 PM
y2knassua00's Avatar
y2knassua00
Navigator
Default corvette dies when put in gear
Ihave a 2000 auto when I put the car in gear it dies only going a foot or two. there are no codes the dealer could find.So far the dealer has not been able to find the problem.It only happens once and while.They cant get to die when checking it out.
Old Jul 3, 2012 | 06:27 PM
87SAM's Avatar
87SAM
Column lock failure. There is a sticky at the top of the page.
Old Jul 4, 2012 | 10:11 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You should see a message on the DIC about the steering column otherwise there should be codes. Other possibilities are bad battery connections or battery at the solenoid. Bad ignition switch, shorting serial interface line and so on...all will show up in codes for the most part.
Old Jul 4, 2012 | 05:48 PM
JJBZ06's Avatar
JJBZ06
i know where this is going... been there and i dont like it.. Here we come Column Lock Failure!
To corvette dies when put in gear
