Lost connection with TAC??
Old Jul 5, 2012 | 01:47 AM
rusty63ss's Avatar
rusty63ss
Default Lost connection with TAC??
I am using an '04 C5 LS1 as a standalone setup in my Nova. When I test fired my motor the DBW worked fine. Today when I tested the instrument cluster it was displaying "Reduced Engine Power" "Service Vehicle". I have 0 response from the TB when the pedal is depressed. My scanner is giving "U0107" Lost communication with TAC module. I checked all my connections to the TAC, PCM, TB, and pedal assembly I do not see anything wrong. What kinds of tests can I do to check the TAC? Is my TAC fried??
Thanks for your help.
Dhamen
Old Jul 5, 2012 | 12:40 PM
rusty63ss's Avatar
rusty63ss
I did store my harness, PCM, TAC, and pedal assembly in a rubbermaid tote over the winter. I thought the TAC was a sealed unit. Could it have moisture in it causing my problem??
Old Jul 5, 2012 | 12:44 PM
lucky131969's Avatar
lucky131969
Doubtful Dhamen. What have you verified with regards to wiring? Correct pinout? Power? Ground?
Old Jul 5, 2012 | 09:47 PM
rusty63ss's Avatar
rusty63ss
Either later tonight or tomorrow I am going to verify that my cobbled up temporary harness between the TAC and pedal does not have a disconnected wire. Then I will recheck all the connections at the PCM etc. When I test fired the engine the DBW worked flawlessly. It will be a year ago next month but it worked. It has to be something simple. I hope.
Old Jul 6, 2012 | 10:48 PM
rusty63ss's Avatar
rusty63ss
I found the issue. I'm such a DA. I forgot to hook up the ignition hot.:o
It works great now!
To Lost connection with TAC??
