M12 blocker Rings... Who has them?
Old Jul 8, 2012 | 03:53 PM
Coc5's Avatar
Coc5
Default M12 blocker Rings... Who has them?
Who sells just the Blocker rings for the M12?
I have my trans torn down for inspection work. I'm actually replacing the drive couplings that are shot with the 6 Shooters. Yes, there will be some heat protection that I will be adding.
Luckily I tore down the trans as I was having issues going into 3rd at higher revs. The blocker ring is worn down to zero clearance.
I attribute that to my obviously dragging Spec 3+ clutch that I am replacing with the RSX clutch.
I also inspected my 4.11 gears that I installed years ago. The Yukon gears still look pretty. Gear oil was in dire need of change though. The Corvette absolutely need more frequent lube changes than other cars and trucks.
Old Jul 9, 2012 | 09:14 PM
Nate B's Avatar
Nate B
http://www.thegearbox.org/T56_corvette.html
